Dan,
Running the tool failed:
Curtis,
Thanks, silly mistake. Using the string literal, however, it produced another error.
arcpy.UpgradeDataset_management(r'\\gisfile\GISstaff\Jared\WillCoGIS_DataSHP_Pro.gdb\Street_Anno')
File "<string>", line 1, in <module>
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 6117, in UpgradeDataset
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 6114, in UpgradeDataset
retval = convertArcObjectToPythonObject(gp.UpgradeDataset_management(*gp_fixargs((in_dataset,), True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 498, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 001267: Dataset type does not support upgrade.
Failed to execute (UpgradeDataset).
Upgrade Dataset—Data Management toolbox | ArcGIS Desktop
According to the Tool Reference page, the GDB in which the feature dataset resides must be updated before the dataset is updated. So, I ran the arcpy.UpgradeGDB_management() function. The resulting error said "the geodatabase is already at the current release". It seems I've come full circle.
default_gdb = r"\\gisfile\GISstaff\Jared\WillCoGIS_DataSHP_Pro.gdb"
arcpy.UpgradeGDB_management(default_gdb, "PREREQUISITE_CHECK", "UPGRADE")
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 6152, in UpgradeGDB
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 6149, in UpgradeGDB
retval = convertArcObjectToPythonObject(gp.UpgradeGDB_management(*gp_fixargs((input_workspace, input_prerequisite_check, input_upgradegdb_check), True)))
ERROR 001046: The geodatabase is already at the current release and cannot be upgraded.
