Enterprise 10.9.0. Hosted feature layers with frequent data updates. Need to rebuild spatial indexes on a regular basis.
When using AGOL, there is an option in the portal item settings which rebuilds the spatial index to improve performance. The option is not available on Enterprise.
What are the common ways for rebuilding the spatial indexes for hosted feature layers on Enterprise?
Thanks in advance.
Hua
Anyone who can comment on this question? Thanks
We experienced performance issues with a frequently updated polygon hosted feature service, believed to be related to indexes needing to be rebuilt. A workaround that worked for us was to export the hosted feature service to a FDGB feature class, then through Pro use the Share>Web Layer>Overwrite Web Layer to replace the same HFS.
Same process, same issue, same workaround.
I'm resurrecting an old post. I'm encountering the same issue on our Enterprise 11.x install. I cannot figure out how to enable the rebuild indexes for managed layers. Any ideas?
Same issue, did you have any success? We have hosted feature layers in AGOL. The "Rebuild Spatial Index" option just hangs, and once it's hung, it is never available again. It will report a "Creating index: Indexes may take a moment depending upon the amount of data." message, one of which I've had now for a month.
Looking under the hood, the Feature Layer Definition JSON shows an "updateLayerDefinitionStatus" of "InProgress", but I've found nothing online for that parameter.
