I am in the process of creating a python script using the ArcGIS API for Python. My goal is to intake a CSV file, analyze it, and publish it. When publishing it, ESRI documentation states that you should be able to take those analyzed parameters (looks like it returns a dictionary) and use those to publish the data. Could someone help me debug this script? When it run it, I get a "job failed" error message, but no description on why it failed.
#import modules
from arcgis.gis import GIS # conda install arcgis -c esri
import os
from pathlib import Path
#create local variables
gis = GIS("home", verify_cert = False)
file = "E:/API_creation/upload/TestUpload.csv"
filename = Path(file).stem
print(filename)
try:
#add content named "file"
csv = gis.content.add(
item_properties = {
"type": "CSV",
"title": filename,
"description": "Just a random Study Area",
"tags": "Clip Area, Study Area",
data = file,
print(file + " uploaded successfully")
#analyze CSV and get attribute dictionary
csv_dict = gis.content.analyze (
item = csv,
file_type = "csv",
print(file + " analyzed successfully")
print(csv_analyzed)
#publish item named "file" as a feature layer
#this needs to be built out so that it enables locations for csvs with lat/long/x/y
spreadsheet_pub = csv.publish(
csv_dict,
print(file + " published successfully")
except Exception as e:
print(e)
