Hi! I'm also dealing with a similar error when I run the Count Trips at Stops tool. I'm running ArcGIS 10.3.1 for desktop, and the Unicode error I get is the following:
Executing: CountTripsAtStops C:\Users\alex_\Desktop\test\test1.gdb\testdusseldorf C:\Users\alex_\Desktop\test\gtfsdusseldorf022019c.sql 20190205 06:00 20:00 Departures
Start Time: Fri Feb 08 23:57:41 2019
Running script CountTripsAtStops...
Creating feature class of GTFS stops...
Calculating the number of transit trips available during the time window...
Writing output data...
Error writing to output.
Failed to count trips at stops.
File "<string>", line 163, in execute
File "C:\Users\alex_\Desktop\D4i_Paper_Metro\BetterBusBuffers\BetterBusBuffers_0.13.0.2\BBB_CountTripsAtStops.py", line 98, in runTool
[str(row[0])], stoptimedict, CalcWaitTime,
UnicodeEncodeError: 'ascii' codec can't encode character u'\xfc' in position 25: ordinal not in range(128)
Failed to execute (CountTripsAtStops).
The GTFS dataset I used as an input is accessible here.
I tried to change the file path or the file name, but it didn't work.
Any ideas for possible solutions?
