Hi Melinda,
Thanks for the quick response!
Honestly I'm at the crunch point of my honors thesis, so I just went ahead a ran with the tools I had available. I haven't done a lot of stuff at this kind of scale before, so I'm not really in a position to judge whether the performance was as expected. For some context, I'm doing an accessibility analysis for access to healthcare in my city, with:
- ~6600 origins (census centroids)
- 5 destinations
- Calculate statistics from 6:30am -> 11:00pm, 30 minutes interval between runs.
With this setup, I found that the tool was taking about 10 - 15mins to solve each run, so about 6hrs compute time to solve each 'day' on the transit network. I repeated for four different days (to cover all variation in the transit schedule), so required 24hrs of compute time.
I would have loved to have simulated a much smaller interval (down at 10 or 5 mins perhaps), but that clearly wasn't an option here. If I'd done 5 min intervals, it would have required ( 10mins run time * 16.5 transit hours * 12 runs/hr * 4 days / 60 mins/hour) 132 of compute time?
So I don't think that is doable. However, I'm still very grateful that I didn't have to write the code from scratch. No urgency on further development, I've got the data I needed for this project. I'm hopeful I'll get the opportunity to continue with this line of inquiry after my thesis, so if you produce a parallel version down the track I'll certainly make good use of it.
Cheers,
Michael
