Hi Andy,
The values (based on the attribute table) look correct. What you could do also is change the near distance value to 1 or 1.5. This should show the image initially without the black globe at the bottom.
The other thing I noticed is that your cam heading is 0. Is this for all images. CamHeading as 0 means that the camera was facing north when the image was taken. but by the looks of your screenshot that particular frame does not look like its facing north. You might want to try using the CalculateHeading' tool to get correct camHeading. But please keep a backup of your data before you use the tool.
Randall
