Using the same workflow, will a map package referencing data in a file geodatabase load into Local Server?
Referencing data option is only for enterprise data.
What about if you include the data in the map package rather than reference it?
If I include the data in the map package, it copies data into FileGDB inside and map package and it works fine.
What version of ArcGIS Pro was the map package created with?
Tried both ArcGIS Pro 2.2 and 2.3.
What version of the ArcGIS Runtime SDK and Local Server are you using?
Tries both ArcGIS Runtime SDK 100.3, 100.4 and Local Server 100.3.
