Is there a way to set the background color for a text symbol in 100?
4731
05-23-2017 07:06 PM
ClayGinn
I've scanned the forum for this and haven't found anything on it. I'm also fairly new to the current ArcGIS Runtime, so be patient with me.
I'm trying to add a background to the text symbols I'm showing, but they don't show up, or else I'm doing it wrong (probably the latter). I tried a composite symbol, but that didn't do what I needed either.
Text label with no background
There needs to be a dark background behind this, but no such luck.
Any suggestions would be greatly appreciated.
AnttiKajanus1
Hi Clay,
This is most likely because it's not there in 100 release. Background property is added to TextSymbol in next release that is coming out quite soon.
ClayGinn
Any time frame on the release? Quite soon is a little ambiguous.
AnttiKajanus1
Hi Clay,
You should be seeing the release coming out from the door in a months time.
