IOS Exception at UIApplication.Main
1462
01-24-2018 02:25 PM
DonKang
I am fairly new to ArcGIS Runtime.
I am building Xamarin Forms app.
I have login page at the beginning and goes to map page once user is authenticated.
For Android, I have no issues. It compiles and behaves how I have it designed to.
However, when I try to test for IOS, I get exception error at Main.cs
// This is the main entry point of the application.
static void Main(string[] args)
// if you want to use a different Application Delegate class from "AppDelegate"
// you can specify it here.
UIApplication.Main(args, null, "AppDelegate");
I've set a break point in my login page and gone through every line of code and nothing really is wrong.
But when login page try's to navigate to the MapPage, I get error message like the attached image.
Appreciated if anyone can share your thoughts.
thanks
Don
MorganHall
I am having the same issue and can't find a solution anywhere. Did you resolve this problem and if you did, how did you resolve it?
Morgan
