Exception loading mpk file
410
01-21-2020 06:38 AM
YaronAvraham
New Contributor III
I'm trying to load mpk file called "l_3" using LocalMapService and get this exception
"Failed to create service l_3 MapServer. Service failed to initialize: Error unpacking map package hr=0x80004005 (No ErrorInfo)"
this is my code:
var mapService = new LocalMapService(fileName);
 await mapService.StartAsync();
StartAsync throws the exception.
I can open the same mpk file on ArcGIS Pro without any problems.
Thanks.
PreetiMaske
Some questions and things to check:
- What are the contents of the mpk? like types of layers, any networks etc.
- What version of ArcGIS Runtime SDK .Net / are you you using?
- If you put a try catch around StartAsync() do you get any additional information?
- Sometimes output window prints out relevant information too. Do you see anything written out there that may be associated to this mpk?
