Create PortalItem with zip file
538
10-19-2022 08:01 AM
JoeHershman
MVP Regular Contributor
We are trying to upload zip files to AGOL.  If I was doing in AGOL I would create the item, define it as a Code Sample (which will allow a generic zip file).
Hoped we could do this in Runtime (100.15).  I see this old thread How to create a new FeatureService PortalItem which seems to indicate only saving Maps is supported, but it is 3 years old so would hope that is no longer the case.
Seems pretty simple:
ZipFile.CreateFromDirectory(projectItem.MapPackagePath, outputfile);
var portalItem = new PortalItem(portal, PortalItemType.CodeSample, projectItem.Title);
using ( var fileStream = File.OpenRead(outputfile) )
	await portalItem.UpdateDataAsync(fileStream);
await portal.User.AddPortalItemAsync(portalItem);
await portalItem.ShareWithGroupsAsync(new[] { group });
Couple problems occur.
  • It requires that the user re-enter credentials on the call to new PortalItem even though authenticated
  • The primary issue: it never returns from the await portalItem.UpdateDataAsync.  It just hangs and so cannot ever put the item in AGOL
Is what I need to do supported?  If so what would be a correct way to do this
Thanks - Joe
-Joe
JoeHershman
Never found a way to get anything to work with the Runtime API, but was able to do using the rest endpoint directly.
string zipfileName = CreateProjectZipfile(projectItem);
/* Does not seem that Runtime API handles creating a zip file item, so using rest API directly
/*    https://developers.arcgis.com/rest/users-groups-and-items/add-item.htm */
string url = $"https://www.arcgis.com/sharing/rest/content/users/{portal.User?.UserName}/additem";
using ( var formContent = new MultipartFormDataContent() )
	AddStringContent(formContent, projectItem);
	AddFileContent(formContent, zipfileName, projectItem);
	using ( HttpClient client = new HttpClient(new ArcGISHttpClientHandler()) )
		var response = await client.PostAsync(url, formContent);
		var json = await response.Content.ReadAsStringAsync();
		await ShareItemWithGroupAsync(json);
private void AddStringContent(MultipartFormDataContent formContent, ProjectItem projectItem)
	Dictionary<string, string> parameters = new Dictionary<string, string>()
		{ "multipart", "false" },
		{ "title", projectItem.Title },
		{ "type", "Code Sample" },
		{ "async", "false" },
		{ "f", "json" }
	//  For MultipartFormDataContent paramaters needs to be added as individual StringContent objects.  FormUrlEncodedContent does not work.
	foreach (var keyValuePair in parameters)
		formContent.Add(new StringContent(keyValuePair.Value), keyValuePair.Key);
private void AddFileContent(MultipartFormDataContent formContent, string outputfile, ProjectItem projectItem)
	var byteArrayContent = new ByteArrayContent(File.ReadAllBytes(outputfile));
	byteArrayContent.Headers.ContentType = new MediaTypeHeaderValue("application/x-zip-compressed");
	byteArrayContent.Headers.ContentDisposition = ContentDispositionHeaderValue.Parse("form-data");
	byteArrayContent.Headers.ContentDisposition.FileName = $"{projectItem.Title}.zip";
	// ContentDisposition.Name needs to match the parameter name
	byteArrayContent.Headers.ContentDisposition.Name = "file";
	formContent.Add(byteArrayContent);
-Joe
PreetiMaske
I believe you can call update only on an existing portal item so I suggest :
- Add PortalItem first then call update
- Enclose UpdateItemAsync() in try catch block to catch any errors.
JoeHershman
No exceptions are being thrown, it just does not return from the method call
-Joe
JoeHershman
		{ "f", "json" }
-Joe
