I am trying to create a new offline locator for use with a Xamarin app, and I was following this guide:
Offline geocode | ArcGIS for Developers
The example works great in my code with the provided san-diego-locator.loc locator, but whenever I try to go and create my own locator and plug it into this example, I get:
Esri.ArcGISRuntime.ArcGISRuntimeException: 'Invalid response'
I have tried creating a few different new locators with different styles and style releases. I have tried known working locators as well, but can't get it working. I have tried to look at the san-diego-locator.loc but weirdly it doesn't even appear as a valid locator in ArcMap and ArcGIS Pro crashes whenever I try to get information on it. When I look at the locator XML files to compare, they look completely different:
Snippet from what I created, these alias tags make up most of the XML:
<alias_def>
<alt>05647</alt>
<alt>5647</alt>
</alias_def>
<alias_def>
<alt>04354</alt>
<alt>4354</alt>
</alias_def>
Snippet from example, made up of completely different tags:
<tr>
<td id="L24500" class="blob-num js-line-number" data-line-number="24500"></td>
<td id="LC24500" class="blob-code blob-code-inner js-file-line"> <<span class="pl-ent">alt</span> <span class="pl-e">ref</span>=<span class="pl-s"><span class="pl-pds">"</span>_blvdbyp<span class="pl-pds">"</span></span>/></td>
</tr>
<tr>
<td id="L24501" class="blob-num js-line-number" data-line-number="24501"></td>
<td id="LC24501" class="blob-code blob-code-inner js-file-line"> <<span class="pl-ent">alt</span> <span class="pl-e">ref</span>=<span class="pl-s"><span class="pl-pds">"</span>_blvdcir<span class="pl-pds">"</span></span>/></td>
</tr>
Any ideas would be appreciated. Any clues on how the locator in the example was made? I am also using Esri.ArcGISRuntime.Xamarin.Forms version 100.7.0 in my Visual Studio project.
Igor
