I have a model with a parameter I can change so that I can run it over different polygon inputs. I am wondering if it is possible to change the name of the outputs within the model and the location to which they output depending on the parameter input.
For example, I am working with rivers inside each continent, so for Africa all the outputs would ideally be named "Africa_Rivers" and be within a folder named "Africa", then I could change the input parameter to Asia and all the outputs would be named "Asia_Rivers" and be within a folder named "Asia".
