Work with schematic diagram using Java SDK
1229
10-20-2016 07:31 PM
BatbayarBazarragchaa
New Contributor III
Is it possible to work with schematic diagrams using Java SDK? I found some samples made with Javascript or Silverlight SDK here:
http://www.arcgis.com/home/group.html?id=5c370c29c824469dae318a2ef2a3ab97
I want to display and edit schematic diagrams using Java SDK. What's the best possible way to do this?
nita14
Occasional Contributor III
Runtime does not support Schematics. Neither Quartz release will do. You should go with ArcObjects for Java.
Regards,
Adam
nita14
Regards,
Adam
