Hi, I'm very new to ArcGIS and have been using the ArcGIS JAVA SDK for a couple of days now. I created the ArcGIS developers account (Essentials Plan) for just exploring things. I'm just interested in reading and writing of data from an online layer. I don't want to display anything on Java FX Maps.
Till now I have been able to read geometrical data for point, polyline and polygon. However I'm facing issues while fetching the non-geometrical attributes. I created a data layer of point geometry and then added a couple of non-geometrical fields in it. Then using the sdk I was also able to insert some values into the layer along with the non-geometrical attribute data. Also the data (including attributes) gets displayed fine on Map2D viewer online
While reading the same data from SDK, I'm able to read geometrical data, however the attributes don't come in the attribute map (
feature.getAttributes() - This gives the default attributes only and not the one I added manually to the layer
Although when I do - featureTable.getFields() - it shows me the defination of fields that I added manually to the layer. They just don't come when I query their values from the feature.
Just need to know is there something I'm missing or may be not available in the essentials plan. Any help will be appreciated.
Thanks.
