I have been developing a desktop application using arcgis-runtime-sdk-java for a few months which I have tested on various MacOS, Windows and Linux installs without issue.
I develop on MacOS and while testing a Windows build of my application recently was without access to my physical Window machine. When running the application on a Windows10 guest under VMware Fusion 12 it crashes consistently as soon as the first MapView is being loaded.
Crash logs attached.
- Host: Macbook Pro 16" 2019
- Host CPU: 2.4 GHz 8-core Intel Core i9
- Host Memory: 64GB DDR4
- Host GPU: AMD Radeon Pro 5600M
- Host OS: MacOS 10.15.7
- Hypervisor: VMware Fusion Pro 12.1.2 (17964953)
- Guest CPU: Intel Core i9-9980HK CPU @ 2.40GHz
- Guest Memory: 8GB
- Guest GPU: VMware SVGA 3D
- Guest OS: Windows 10 Pro x64 20H2 19042.1288
- JavaFX: OpenJFX 16
$ ~/.jdks/semeru-16.0.2/bin/java -version
openjdk version "16.0.2" 2021-07-20
IBM Semeru Runtime Open Edition 16.0.2.0 (build 16.0.2+7)
Eclipse OpenJ9 VM 16.0.2.0 (build openj9-0.27.0, JRE 16 Windows 10 amd64-64-Bit Compressed References 20210730_69 (JIT enabled, AOT enabled)
OpenJ9 - 1851b0074
OMR - 9db1c870d
JCL - 34df42439f3 based on jdk-16.0.2+7)
Stack trace for the crashed thread:
1XMCURTHDINFO Current thread
3XMTHREADINFO "JavaFX Application Thread" J9VMThread:0x0000000000238C00, omrthread_t:0x0000026C8C80BD70, java/lang/Thread:0x000000008026CD08, state:R, prio=5
3XMJAVALTHREAD (java/lang/Thread getId:0x1C, isDaemon:false)
3XMTHREADINFO1 (native thread ID:0x16E4, native priority:0x5, native policy:UNKNOWN, vmstate:R, vm thread flags:0x00000020)
3XMCPUTIME CPU usage total: 5.406250000 secs, user: 2.453125000 secs, system: 2.953125000 secs, current category="Application"
3XMHEAPALLOC Heap bytes allocated since last GC cycle=0 (0x0)
3XMTHREADINFO3 Java callstack:
4XESTACKTRACE at com/esri/arcgisruntime/internal/mapping/view/RenderingContext.nativeDrawMap(Native Method)
4XESTACKTRACE at com/esri/arcgisruntime/internal/mapping/view/RenderingContext.drawMap(RenderingContext.java:118)
4XESTACKTRACE at com/esri/arcgisruntime/internal/mapping/view/GeoViewSkin$1.drawRequested(GeoViewSkin.java:84)
4XESTACKTRACE at com/esri/arcgisruntime/internal/jni/CoreGeoView.onDrawRequested(CoreGeoView.java:489)
4XESTACKTRACE at com/esri/arcgisruntime/internal/mapping/view/RenderingContext.nativePulse(Native Method)
4XESTACKTRACE at com/esri/arcgisruntime/internal/mapping/view/RenderingContext.pulse(RenderingContext.java:106)
4XESTACKTRACE at com/esri/arcgisruntime/internal/mapping/view/PulseThread$1$$Lambda$1691/0x00000000b5c06dc8.accept(Bytecode PC:4)
4XESTACKTRACE at java/util/concurrent/CopyOnWriteArrayList.forEach(Bytecode PC:37)
4XESTACKTRACE at com/esri/arcgisruntime/internal/mapping/view/PulseThread$1.handle(PulseThread.java:31)
4XESTACKTRACE at javafx/animation/AnimationTimer$AnimationTimerReceiver.lambda$handle$0(AnimationTimer.java:57)
4XESTACKTRACE at javafx/animation/AnimationTimer$AnimationTimerReceiver$$Lambda$1690/0x00000000ae9ca8f8.run(Bytecode PC:8)
4XESTACKTRACE at java/security/AccessController.doPrivileged(Bytecode PC:3)
4XESTACKTRACE at javafx/animation/AnimationTimer$AnimationTimerReceiver.handle(AnimationTimer.java:56)
4XESTACKTRACE at com/sun/scenario/animation/AbstractPrimaryTimer.timePulseImpl(AbstractPrimaryTimer.java:356)
4XESTACKTRACE at com/sun/scenario/animation/AbstractPrimaryTimer$MainLoop.run(AbstractPrimaryTimer.java:266)
4XESTACKTRACE at com/sun/javafx/tk/quantum/QuantumToolkit.pulse(QuantumToolkit.java:559)
4XESTACKTRACE at com/sun/javafx/tk/quantum/QuantumToolkit.pulse(QuantumToolkit.java:543)
4XESTACKTRACE at com/sun/javafx/tk/quantum/QuantumToolkit.pulseFromQueue(QuantumToolkit.java:536)
4XESTACKTRACE at com/sun/javafx/tk/quantum/QuantumToolkit.lambda$runToolkit$11(QuantumToolkit.java:342)
4XESTACKTRACE at com/sun/javafx/tk/quantum/QuantumToolkit$$Lambda$108/0x00000000a061a9b8.run(Bytecode PC:4)
4XESTACKTRACE at com/sun/glass/ui/InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:96)
4XESTACKTRACE at com/sun/glass/ui/win/WinApplication._runLoop(Native Method)
4XESTACKTRACE at com/sun/glass/ui/win/WinApplication.lambda$runLoop$3(WinApplication.java:174)
4XESTACKTRACE at com/sun/glass/ui/win/WinApplication$$Lambda$104/0x00000000a0512aa8.run(Bytecode PC:12)
4XESTACKTRACE at java/lang/Thread.run(Bytecode PC:13)
3XMTHREADINFO3 Native callstack:
4XENATIVESTACK RT_Vector_setElementRemovedCallback+0x26590cd (0x0000026CB1C155ED [runtimecore+0x29e55ed])
4XENATIVESTACK RT_Vector_setElementRemovedCallback+0x1b1e62a (0x0000026CB10DAB4A [runtimecore+0x1eaab4a])
4XENATIVESTACK RT_Vector_setElementRemovedCallback+0x1af1fb2 (0x0000026CB10AE4D2 [runtimecore+0x1e7e4d2])
4XENATIVESTACK RT_Vector_setElementRemovedCallback+0x7a1954 (0x0000026CAFD5DE74 [runtimecore+0xb2de74])
4XENATIVESTACK RT_GeoView_drawToBuffer+0x59 (0x0000026CAF4ADEC9 [runtimecore+0x27dec9])
4XENATIVESTACK Java_com_esri_arcgisruntime_internal_mapping_view_RenderingContext_nativeDrawMap+0x104 (0x00007FF9FCD91B24 [runtimecore_java+0x91b24])
4XENATIVESTACK Java_com_esri_arcgisruntime_internal_mapping_view_RenderingContext_nativeDrawMap+0x92 (0x00007FF9FCD91AB2 [runtimecore_java+0x91ab2])
4XENATIVESTACK J9_GetInterface+0xbd893 (0x00007FFA18BDC7A3 [j9vm29+0x19c7a3])
4XENATIVESTACK J9_GetInterface+0xbd2e8 (0x00007FFA18BDC1F8 [j9vm29+0x19c1f8])
4XENATIVESTACK (0x00007FFA18A55D1B [j9vm29+0x15d1b])
4XENATIVESTACK (0x000000F1244FD9A0)
4XENATIVESTACK (0x000000F1244FDAC8)
4XENATIVESTACK (0x000000F1244FDA01)
4XENATIVESTACK (0x000000F1244FD850)
