hello, i am using arcgispro 2.8, my GPU is Radeon graphics 3.9 GB, i have an error while runiing the tool "detect object using deep learning" , the dlpk file is downloaded from living atlas : usa_building footprint.dlpk,
my input raster is 7.5cm resolution, while running this tool on the CPU the running progression shows always 0% ( even after 6 hours...) , by running it on GPU i have the error : arcgis pro has experienced a fatal authorization error and must close,
please to help me in solving this,
thank you
@SanaaAmirSaad can you try the model with a very small area and see if it works with CPU? I will get back to you on the GPU issue.
The tools only support CUDA compatible GPUs.
