detect object using deep learning tool
502
10-18-2022 11:54 AM
SanaaAmirSaad
hello, i am using arcgispro 2.8, my GPU is Radeon graphics 3.9 GB, i have an error while runiing the tool "detect object using deep learning" , the dlpk file is downloaded from living atlas : usa_building footprint.dlpk,
my input raster is 7.5cm resolution, while running this tool on the CPU the running progression shows always 0% ( even after 6 hours...) , by running it on GPU i have the error : arcgis pro has experienced a fatal authorization error and must close,
please to help me in solving this,
thank you
PavanYadav
@SanaaAmirSaad can you try the model with a very small area and see if it works with CPU? I will get back to you on the GPU issue.
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
PavanYadav
The tools only support CUDA compatible GPUs.
Pavan Yadav
AI for Imagery
