ArcGIS Pro 2.8.2: Where can the “Build Frames & Cameras Tables” command be found?
670
10-01-2021 11:01 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out where the “Build Frames & Cameras Tables” command be found. It’s not populated in the geoprocessing pane.
Jamal Numan
JayantaPoddar
MVP Esteemed Contributor
You could access the tool after adding the tool to ArcGIS Pro.
Think Location
JayantaPoddar
Think Location
JamalNUMAN
Thank you JayantaPoddar for the help. The screenshot makes it easy for me to get the tool
Jamal Numan
DanPatterson
it is described in this help topic
Build Frames and Cameras Tables Tool—ArcGIS Pro | Documentation
... sort of retired...
JamalNUMAN
But I’m wondering why this command isn’t within the Geoprocessing tools
Jamal Numan
