Speed up ST Functions
5126
6
02-17-2015 10:31 AM
NicoleSchleifer
New Contributor II
We are working on migrating our existing applications from SDO_Geometry into ST_Geometry (Oracle 11g - SDE 10.2.2).
One of our applications uses an iPad to get the X, Y coordinates and locate the closest linear asset.
Our SDO sql statement was simple:
WHERE SDO_WITHIN_DISTANCE ( A.AREAGEOMETRY ,mdsys.sdo_geometry(2001, 8307,
mdsys.sdo_point_type( -78.2990416, 44.29297897, NULL), NULL, NULL),  'distance=75') = 'TRUE'
The response time is 196 msecs
Attempting to duplicate the results using ST functions is a little frustrating
I have not been able to us the x, y points from the iPad at all, so I've been uisng the UTM coordinates.
I've been able to reproduce the results using the UTM coordinates but the response time is way too slow (see below)
14 secs
where sde.st_intersects (sde.st_buffer(sde.st_point(715480.6, 4907962.3, 26917), 15 ),pl.shape) = 1
11 secs
where sde.st_distance (sde.st_point(715480.6, 4907962.3, 26917),pl.shape)  < 15
9 secs
where sde.st_distance (sde.st_geometry(715480.6, 4907962.3,null,null, 26917),pl.shape)  < 15
Does anyone have any advice for how to speed the response time up?
Are these the correct sql functions? or am I missing one?
Please let me know.
Tags (3)
VinceAngelo
Esri Esteemed Contributor
Not having the data, and not having the time to simulate some, I'm not fond of specifying a query, but something like:
WHERE sde.st_envintersects(pl.shape,715480.6-15,4907962.3-15,715480.6+15,4907962.3+15) = 1
     and  sde.st_distance (sde.st_geometry(715480.6, 4907962.3,null,null, 26917),pl.shape)  < 15
ought to work reasonably quickly.
You need to review the query plan to determine whether the index is being used, but I can't give you further information than that.  You may need to work with Tech Support to determine the optimal query (it doesn't help that the old query was in WGS_1984).  It's possible that a 530 meter index grid is inappropriate for that dataset (but couldn't say for sure without the data).
BTW: change the "15"s to "75"s if you want a similar result as Oracle with a "75" query.
- V
VinceAngelo
The st_distance query is doing a full table scan (not using the spatial index), so you need to get the spatial index in play by using sde.ST_ENVINTERSECTS in the first term of the WHERE clause.  The ST_INTERESECTS query should have been enough to engage the spatial index, so I also wonder if you have the index available.
- V
NicoleSchleifer
New Contributor II
We have the standard Spatial Index created through the desktop tools:
INDEXTYPE IS SDE.ST_SPATIAL_INDEX
PARAMETERS('ST_GRIDS = 530 ST_SRID = 26917 ST_COMMIT_ROWS = 10000  PCTFREE 0 INITRANS 4')
NOPARALLEL;
Is there a way to test if the query is calling the spatial index?
Secondly, I'm a little unsure of how/where to use the st_envintersects ? Am I replacing the st_intersect with it? or do I need to use them both?
VinceAngelo
- V
NicoleSchleifer
New Contributor II
Totally understandable. You're response is appreciated.
I will continue on this path.
Thanks
NicoleSchleifer
New Contributor II
THANK-YOU SO MUCH! It works perfectly!!!
Response time is now 264 msecs......... SO EXCITING!!!
Bud
Notable Contributor
