I am using ArcMap 10.4.1. If I go to File -> Add Data ->Add Query layer I can fill out everything, validate it, and hit ok - then it starts to run and ArcMap Crashes. I can use the "Make Query (Data Management)" Tool and successfully create a Query Layer, but it does Not show up in "Layers" in the TOC . See Screenshot.
The data is there, and I can use the identify tool to get information about the polygons. If i switch to List by Source, Visibility, or Selection in the TOC, sometimes the Query Layer will appear there and sometimes it won't. If I open an existing mxd with a query layer already in it, I can modify the Query and everything functions correctly. Any thoughts as to what is going on?
Thanks!
Pamela
