Hi Marcelo,
thank you for your reply. It is important to respect the right order when importing. In our case the cause was was slightly different. When importing the SDE user first we got the same error message again - one which I did not post in my original question. That error message in full is:
Failing sql is:
CREATE INDEXTYPE "SDE"."ST_SPATIAL_INDEX" FOR "SDE"."ST_BUFFER_INTERSECTS" ("SDE"."ST_GEOMETRY", "SDE"."ST_GEOMETRY", NUMBER), "SDE"."ST_CROSSES" ("SDE"."ST_GEOMETRY", "SDE"."ST_GEOMETRY"), "SDE"."ST_ENVINTERSECTS" ("SDE"."ST_GEOMETRY", NUMBER, NUMBER, NUMBER, NUMBER), "SDE"."ST_ENVINTERSECTS" ("SDE"."ST_GEOMETRY", "SDE"."ST_GEOMETRY"), "SDE"."ST_ENVINTERSECTS" ("SDE"."ST_GEOMETRY", NUMBER, NUMBER, NUMBER, NUMBER, VARCHAR2), "SDE"."ST_ENVINTERSECTS" ("SDE"."ST_GEOMETRY", "SDE"."ST_GEOMETRY", VARCHAR2), "SDE"."ST_EQUALS" ("SDE"."ST_GEOMETRY", "SDE"."ST_GEOMETRY"), "SDE"."ST_INTERSECTS" ("SDE"."ST_GEOMETRY", "SDE"."ST_GEOMETRY"), "SDE"."ST_ORDERINGEQUALS" ("SDE"."ST_GEOMETRY", "SDE"."ST_GEOMETRY"), "SDE"."ST_OVERLAPS" ("SDE"."ST_GEOMETRY", "SDE"."ST_GEOMETRY"), "SDE"."ST_RELATE" ("SDE"."ST_GEOMETRY", "SDE"."ST_GEOMETRY", VARCHAR2), "SDE"."ST_TOUCHES" ("SDE"."ST_GEOMETRY", "SDE"."ST_GEOMETRY"), "SDE"."ST_WITHIN" ("SDE"."ST_GEOMETRY", "SDE"."ST_GEOMETRY") USING "SDE"."ST_DOMAIN_METHODS" WITHOUT ARRAY DML WITH LOCAL RANGE PARTITION
Processing object type SCHEMA_EXPORT/INDEXTYPE/GRANT/OWNER_GRANT/OBJECT_GRANT
ORA-39112: Dependent object type OBJECT_GRANT:"SDE" skipped, base object type INDEXTYPE:"SDE"."ST_SPATIAL_INDEX" creation failed
Processing object type SCHEMA_EXPORT/TABLE/STATISTICS/TABLE_STATISTICS
Processing object type SCHEMA_EXPORT/TABLE/INDEX/DOMAIN_INDEX/INDEX
ORA-39083: Object type INDEX:"ELEAHS"."A3570_IX1" failed to create with error:
ORA-29833: indextype does not exist
As it turns out this issue was only resolved after installing/configuring Oracle Spatial. I dont have any further details as this was done by our DB admin. There was also a bit of confusion about Oracle Multimedia and Locator as MM is not supported anymore in 19c but Locator is.
With this issue solved and importing the SDE user first the error message I mentioned above did not occur again.
Regards, Robert
