Corrupt ESRI Learning file
757
06-16-2023 01:09 PM
PPoudel
New Contributor II
I am unsure if this the correct forum to post this, but as I was going through the ESRI course 'Change Detection Using Imagery', I was asked to download a zip file containing the data required to complete that module.
However, it appears that the zip file is corrupt. I tried downloading it several times, but I get a 7-zip error 'Unexpected end of data'
I have not had this problem with any other zip file I've downloaded for the other courses, I was wondering if this could be corrected or if I could sent a non-corrupt zip file? The file is supposed to contain a polygon of Glacier National Park without which I am unable to follow along with the content.
Suzanne-Boden
Hi, our team can't replicate the data extraction issues in either course, but notes that the files that are not extracting for you are large. Potentially there's a system issue on the machine you're using. Please reach out to support@esri.com and they can help you troubleshoot.
Suzanne-Boden
Hi, sorry to hear you've run into an issue. This course is available for multiple versions of ArcGIS Pro. Which version are you taking?
PPoudel
New Contributor II
Hi Suzanne, thanks for responding. I am taking the Pro 3.1 version
Suzanne-Boden
Hi, our team is looking into this.
PPoudel
New Contributor II
Adding another comment because there is a similar issue with the course 'Creating 3D Features from Existing Data' for ArcGIS Pro 3.1
Suzanne-Boden
