Using Pandas
Python from ArcMap comes with some modules. You can load the data into a pandas.DataFrame and work with this format. Pandas is well-documented and there is a lot of already asked question about it all over the web. It's also super easy to do groupby or table manipulations.
import pandas as pd
import arcpy
def read_arcpy_table(self, table, fields='*', null_value=None):
Transform a table from ArcMap into a pandas.DataFrame object
table : Path the table
fields : Fields to load - '*' loads all fields
null_value : choose a value to replace null values
fields_type = {f.name: f.type for f in arcpy.ListFields(table)}
if fields == '*':
fields = fields_type.keys()
fields = [f.name for f in arcpy.ListFields(table) if f.name in fields]
fields = [f for f in fields if f in fields_type and fields_type[f] != 'Geometry'] # Remove Geometry field if FeatureClass to avoid bug
# Transform in pd.Dataframe
np_array = arcpy.da.FeatureClassToNumPyArray(in_table=table,
field_names=fields,
skip_nulls=False,
null_value=null_value)
df = self.DataFrame(np_array)
return df
# Add the function into the loaded pandas module
pd.read_arcpy_table = types.MethodType(read_arcpy_table, pd)
df = pd.read_arcpy_table(table='path_to_your_table')
# Do whatever calculations need to be done
Using CURSOR
You can also use arcpy cursors and dict for simple calculation.
There are simple example on this page on how to use correctly cursors : https://desktop.arcgis.com/fr/arcmap/10.3/analyze/arcpy-data-access/searchcursor-class.html
