More Power for Your GIS Analysis through Joining Features to ArcGIS Online
2607
02-23-2018 06:00 AM
JosephKerski
Esri Notable Contributor
2 0 2,607
Because the problems that GIS analysts work on such as biodiversity loss and water quality do not stop at disciplinary or political boundaries, the ability to connect the map or attribute table that you are working on to another map or table in the same geodatabase or another geodatabase is powerful.  One way of doing this is to join features.  This has been a core function and a chief argument for the use of GIS for decades.  But with the advent of ArcGIS , including its Join Features tool along with data layers in the Living Atlas of the World, the ability that you have at your fingertips for joining features just became a lot more powerful.  I first saw a demonstration of this at the Esri User Conference from my colleague Jennifer Bell and I thought, "this is a fantastic capability for educators... and people in other sectors of society."
Why is this so incredible?  In the past, to join your data to another data set, you had to spend some time downloading and formatting that data set; sometimes you had to add additional fields and populate them, before that data set was usable in your GIS.  But the bottom line is that you now have access to data sets in the cloud, for example, in the Living Atlas of World.  And, similar to the capabilities included in the Enrichment tool, these data sets do not have to be on your own device or in your own geodatabase to use them!
Additionally, you now have the capability of making choropleth maps from tabular data using the Join Features option.  Let’s say you have a CSV (comma separated value) table containing data for a set of polygons, such as ZIP codes in a state, or US states, or world countries.  If you add that table to ArcGIS  and make a map out of it, your result will be a set of points, one for each record in your table.  If your table represents world countries, your map will show one point in each country.  This is a useful exercise if you are teaching about geocoding in a GIS course but not so useful if your goal is to obtain a choropleth map on specific variables for your desired set of polygons.  In the past, your choices at this stage would be to use Esri Maps for Office to turn your table into a set of polygons in ArcGIS , or to use ArcMap or ArcGIS Pro to join your table to a table associated with an existing shapefile or geodatabase.  But now you can also use ArcGIS  to create a choropleth map!
How can you do this?  You can do this via the Join Tables tool and by accessing the Living Atlas of the World.  First, log into your account in ArcGIS .  Then > Map > Modify Map > Add Data.  Add your spreadsheet.  Need a spreadsheet?  The World Bank has a wide variety of data sets by country in tabular form.  Indicate the field (such as country code) for your place-based table, and the result will be a set of points, similar to that below (shown on the colored pencil base map, which I love):
Point map
That is all good, but now for the really exciting part:  To make a choropleth map by country of this same data: Perform Analysis > Join Features, on step 1, select Choose Living Atlas Analysis Layer, and for step 2, choose your table, which  now resides in ArcGIS  as a layer, and join on a common field. In this example, I had no common field, so I first had to add a field in Excel for the 2 digit ISO country code and populate that field with the code.  Why?  Because the ISO 2 digit code did not exist in the World Bank table.  This is a good example of knowing your data and what you need to sometimes do to enable joins to take place.
Using the Join Features tool, 1
While running the Join Features tool, select the Living Atlas, search for World Countries, and choose World Countries, as shown below:
Using the Join Features tool, 2
Therefore, you are joining your agricultural land table (#2) to the World Countries (Generalized) from the Living Atlas, as shown below:
Using the Join Features tool, 3
Indicate the fields that will serve as your join fields, as I have done below.  I will be joining on the 2 digit ISO code.  When possible, join on a code rather than names (of cities, countries, and so on) due to spelling differences, which will adversely affect your match rate.
Using the Join Features tool, 4
The result is a map joined to your original table!  Now, with the map at your fingertips, you can map any of your table attributes, such as agricultural land by country for 2015, as I have done below.
Resulting map
Now let's dig a little deeper.  Since we are working with agricultural land over time, we can create a custom Arcade expression that will allow us to visualize changes around the world.  I created a custom expression below, subtracting the 1980 percent agricultural land by country by the percent in 2015, as shown below.  Since the data are already in percent, there was no need to multiple by 100 (again, knowing your data is key!):
Custom expression
I also want the popup to display the change over time, and so I will add the same expression shown above to the popup custom attribute display, as shown below:
Custom popup configuration
The resulting map and popup are shown here.  What patterns do you notice? Why the big increase in Saudi Arabia, for example?  You could zoom in, change the basemap to imagery, and investigate the new center pivot irrigated fields in the middle of that country.  You could pan over to Brazil and examine fields reclaimed from wetlands and rainforest.  You could examine urban spawl in the USA and elsewhere as part of your investigation into why agricultural land has declined in many areas of the world.  Because I believe a data set like this is valuable to teach many core themes in environmental science, economics, and physical and cultural geography, I have shared the table here.
Map using custom expression for legend and for popup
For more information about the Living Atlas, explore it here.  For more information about the Join tool in ArcGIS , examine this document
I have created a video on this topic, here: While this is really a paradigm-changing workflow, I used a simple example to hopefully get the point across:    https://youtu.be/TjFZh7UbLZk
Joining data to ArcGIS Living Atlas of the World.
About the Author
I believe that spatial thinking can transform education and society through the application of Geographic Information Systems for instruction, research, administration, and policy. I hold 3 degrees in Geography, have served at NOAA, the US Census Bureau, and USGS as a cartographer and geographer, and teach a variety of F2F (Face to Face) (including T3G) and online courses. I have authored a variety of books and textbooks about the environment, STEM, GIS, and education. These include "Interpreting Our World", "Essentials of the Environment", "Tribal GIS", "The GIS Guide to Public Domain Data", "International Perspectives on Teaching and Learning with GIS In Secondary Education", "Spatial Mathematics" and others. I write for 2 blogs, 2 monthly podcasts, and a variety of journals, and have created over 6,500 videos on my Our Earth YouTube channel. Yet, as time passes, the more I realize my own limitations and that this is a lifelong learning endeavor: Thus I actively seek mentors and collaborators.
