Hello
We need to make a trigger that obtains the object id that is being updated in a non versioned feature class, this value is a parameter for a store produre.
The feature class is publish as a service because we need to collect data with the collector app for our leaks.
We took a trigger from the geonet community as a example but it shows an error when we update the record.
Thank you for the help!
Gaby
AFTER UPDATE
AS
declare @orderservi varchar (10)
declare @estatus integer
BEGIN
SET NOCOUNT ON;
UPDATE [SDE].[CEA_FUGASQROVCT]
SET FallaHoraI = getdate()
WHERE OBJECTID IN (SELECT OBJECTID FROM INSERTED)
SET FallaHoraF = getdate()
SELECT TOP 1 @orderservi =OrdenServi from sde.CEA_FUGASQROVCT WHERE OBJECTID IN (SELECT OBJECTID FROM INSERTED)
SELECT TOP 1 @estatus = Estatus from sde.CEA_FUGASQROVCT WHERE OBJECTID IN (SELECT OBJECTID FROM INSERTED)
If @estatus = 502
exec dbo.cea_pr_fuga_gis @orderservi
END
GO
