Data Pipelines Questions
96
46.3K
30
Open | In the Manage Schedules window, please create the ability to search, sort, and filter schedules based on any availabl... by JamesDrumm2 New Contributor III 1 1 | 1 | 1 | |
Implemented | In the past week a handful of our data pipelines have failed to complete and sat in a pending status for 2 hours befo... by JamesDrumm2 New Contributor III 0 3 | 0 | 3 | |
Open | My organization has several admin users and dozens pipelines spread between each user. Currently only the owner of a... by JamesDrumm2 New Contributor III 0 2 | 0 | 2 | |
Open | It would be very useful to be able to execute a data pipeline via an API. What this would enable is the ability to or... by CarterHughes New Contributor II 0 2 | 0 | 2 | |
Open | Currently through ArcGIS Online, you can go to a Feature Layer and choose to Export all of the contents of that Featu... by MattReeves_SpokaneValley New Contributor III 0 0 | 0 | 0 | |
Open | We have many scripts running now that update AGOL layers from File Geodatabase Feature Classes written in python (arc... by Levon_H New Contributor III 0 1 | 0 | 1 | |
Open | Please add SQL Server on Azure as a database choice to access data. We store well records with coordinates and would... by RobertGrahamJR New Contributor III 3 2 | 3 | 2 | |
Open | AWS S3 buckets are supported already. However, there are many S3-compatible services out there. For example, Digital ... by dspriggs New Contributor II 1 0 | 1 | 0 | |
Open | I would like the ability to connect to Palantir Foundry, select a dataset and use that data as an input for Data Pipe... by ScottShield New Contributor III 0 0 | 0 | 0 | |
Open | Looking at Data Pipelines and how it could be used to manipulate data and automate new workflows instead of developin... by LindsayRaabe_FPCWA Regular Contributor II 0 0 | 0 | 0 | |
Open | I'm attempting to do a spatial join and unfortunately the 2 input datasets have different spatial references. This me... by LindsayRaabe_FPCWA Regular Contributor II 0 3 | 0 | 3 | |
Implemented | Pretty straight forward idea. Include all options that exist in ArcGIS Online filter expressions in Data Pipline filt... by LindsayRaabe_FPCWA Regular Contributor II 0 4 | 0 | 4 | |
Open | We are implementing databricks (https://www.databricks.com/) for building a data lakehouse for advanced data analytic... by Tilt_Martin New Contributor II 2 1 | 2 | 1 | |
Open | Hi,Some to a lot of data is published as a layer in a MapServer service, for example the site below:https://gisservic... by rob_hewy Occasional Contributor 0 1 | 0 | 1 | |
Open | Hi,Would be nice to have koop output as a data input for pipelines.Regards,Rob by rob_hewy Occasional Contributor 0 0 | 0 | 0 |
Idea Submission Guidelines
User | Count |
1 | |
1 | |
1 | |
1 |
