I am trying to write a script using the select tool to select only those rows with the field description "Seaplane Base". I can get the other value, "Airport" to work, but when I run the script, it gives me an empty table in the new file when selecting "Seaplane Base".
import arcpy
arcpy.env.workspace = "###"
infc = "airports.shp"
outfc = "airports_sea.shp"
delim_field = arcpy.AddFieldDelimiters(infc, "FEATURE")
sql_exp = delim_field + " = 'Seaplane Base'"
arcpy.Select_analysis(infc, outfc, sql_exp)
Please help
