Seeing all the files in a folder
659
10-06-2022 07:57 AM
Alfred_Baldenweck
New Contributor II
Hi all,
I'm planning a huge cleanup of our office's GIS file structure.
Part of that cleanup is deleting unnecessary folders.
Right now, my workflow is to look at the folders in both Catalog and in normal File Explorer to determine whether they're actually empty or not; Catalog won't show PDFs, for example, but File Explorer can't show me GIS data in a clean way (Hello, 9 different files for 1 shapefile, and 100 files per file gdb.)
Is there a viewer that shows ALL the contents of a folder in a readable way?
Thanks!
Edit: I know I can script to check if a folder is empty, but I'm looking for a GUI solution.
AlfredBaldenweck
MVP Regular Contributor
DanaNolan
Occasional Contributor III
So this is an ArcPro limitation. Do you have access to ArcMap? Because you can add lots of filetypes to ArcCatalog's display in ArcMap, including zips and PDFs.
I use 2 windows for cleanup and conversion: ArcCatalog and Windows. But it sounds like you have data and map output in the same folder. This "project" orientation makes cleanup much harder.
AlfredBaldenweck
I was able to figure it out with ArcCatalog. Not sure why Esri didn't make it default functionality for Pro, but I guess that's why we have the Ideas forum.
https://desktop.arcgis.com/en/arcmap/latest/manage-data/using-arccatalog/using-arccatalog-options.ht...
RobertJost
New Contributor II
Could you elaborate on folder structures that avoid the "project" orientation?
DanaNolan
We keep data separate, organized at the top level or two by SDSFIE topics or in a few cases by owner. Layer files are kept with data.
Map projects and exported maps are also separate from one another. We can move map projects and output files easily, but moving data is always harder because of links.
Map projects and output are also organized by SDSFIE topic and owner, although those that are not meant to be permanent are usually stored in a "temporary" folder. I don't think there is any way to avoid some miscellaneous folders for maps or strange bits of data, especially with 3+ people creating them. I just periodically try to find better locations for them or to toss them.
Map projects that are more permanent (reusable) or that are good templates are stored higher up in the map project file folders. We often have an "older" and "one-off" and "testing" subfolders. We try to avoid updating these subfolder maps with new links or when software changes.
I also like keeping editing maps and some analysis maps separate from cartographic maps, not inside topic folders. They are too different and a little risky for anyone other than their creators or experienced analysts to use. They can be great documentation, though, because they can tell a story of how the data came to be, which is incredibly useful when cleaning up after a complex edit or analysis process. I start some of my editing maps over from scratch after major software or data changes (so they run better).
