Reindex GDB Tables
463
5
03-14-2024 05:08 AM
CodyPatterson
Hey All,
Enterprise 11.2 Geodatabase.
I have been reindexing our Enterprise Geodatabase every day, as we write quite often to this DB, and have noticed using a fragmentation query, that we have a few tables that don't seem to reindex, these include GDB_ITEMS and SDE_column_registry. These are unable to be selected via ArcGIS Pro, so I was curious if these should be reindexed, or if these should just be disregarded, they are quite large.
Thanks in advance!
Cody
2 Solutions
KimberleeHermann1
Hello...if you are using SQL Server it is super easy to use the Maintenance Plan wizard and do a reindex of everything on a database. Usually doesn't take long at all. I have it scheduled for all of my databases each weekend and that seems to keep thing "all good".
MarceloMarques
@CodyPatterson - I usually avoid using the ArcGIS Pro GP Tools to gather new statistics and to rebuild indexes (attribute indexes and spatial indexes ) in my production geodatabases because these tools to not offer advanced options that you find with the SQL Server SQL Commands to do the same. I suggest you use the SQL Server Tools to do this maintenance.
You can find my maintenance scripts for SQL Server in my community.esri.com blog below, download the database template scripts for SQL Server.
Mapping and Charting Solutions (MCS) Enterprise Da... - Esri Community
Your question about the GDB_ITEMS table and any other ArcSDE Repository Tables. Yes, those tables must be reindexed as well, probably not every day, as you will not be creating new featureclasses, etc. in the geodatabase, but you should reorganize indexes weekly and rebuild indexes monthly at least for the ArcSDE Repository Tables, and right after that gather new statistics.
For reference to others about this discussion follow below the links for the ArcGIS Pro GP Tools.
Enterprise geodatabase maintenance tasks—ArcGIS Pro | Documentation
Modify a spatial index—ArcGIS Pro | Documentation
Rebuild Indexes (Data Management)—ArcGIS Pro | Documentation
Update database statistics—ArcGIS Pro | Documentation
I hope this helps.
| Marcelo Marques | Principal Product Engineer | Esri |
| Cloud & Database Administrator | OCP - Oracle Certified Professional |
I work with Enterprise Geodatabases since 1997.
“ I do not fear computers. I fear the lack of them." Isaac Isimov
KimberleeHermann1
CodyPatterson
Hey @KimberleeHermann1
Thank you for that tip, I was not sure if the SQL way would be preferable, or the ArcGIS Pro way, but it seems that the SQL way is more preferred! I will give that a shot and go through with it that way, my initial assumption was that since they are ArcGIS Pro provided indexes through GDB functionality, then they could only be rebuilt within Pro, but we learn as we go!
Cody
MarceloMarques
I hope this helps.
CodyPatterson
Hey @MarceloMarques
Thank you for the tip! I will check that out to see what I can manage with that! I spoke with another commenter and said that I was not confident on which method to use, since my assumption was that since it's a Pro index, I must do it in Pro, but it looks like that's incorrect.
I appreciate the documentation too!
Cody
KimberleeHermann1
You are very welcome!! So glad it worked for you.
