Clean geometry like clean-command in ArcInfo-Workstation
642
10-30-2012 01:17 AM
Status: Open
HagenProbsthain1
New Contributor III
As long as the clean command is not implemented with comparable functionality, missing an important building block to produce accurate geometries. Maybe the tool "Repair" can be extended.
2 Comments
MarcoBoeringa
You may find this thread on the Gis StackExchange forum useful.
What is the modern equivalent to ArcInfo CLEAN?
I recently discovered the Integrate command myself as referenced also in the link above, and found it useful for cleaning up badly digitized polygons (overlaps, gaps):
"Integrate" geoprocessing tool
JeniferBarnes
The ability to flatten polygons without having to click on each overlap is necessary.  The coverage dataset only allowed overlaps using regions.  We need this data structure back, I can't do my work without it.
