Calculating Geometry of Data Collected in UTM
4422
05-06-2015 01:44 PM
deleted-user-W17i9rKaOdiH
If I have point data that were collected in UTM based on a datum other than WGS1984, can I use the calculate geometry function to get the point value in lat/long or do I first need to project the data and do a datum transformation before I calculate geometry?
I experimented with this by: 1.  importing data collected in UTM based on WGS84; 2. creating two fields for the lat/long values; 3. setting the data frame to WGS84; 4. calculated geometry based on data frame with decimal degrees output versus first projecting the imported data to WGS84 before I do steps 1-4, and I get the exact same coordinate value.
I am wondering if this would be the case if the data were collected with UTM based on a local datum. Is it best practice to first project and transform the data before calculating geometry?
Any thoughts?
Carlynne
MelitaKennedy
Esri Notable Contributor
Lyndy,
The only thing to change (if you're not doing it already) is to make sure you set a geographic/datum transformation in the map/data frame between the local datum and WGS84.
I just created some NAD27 UTM data and calc'ed the NAD27 latitude and longitude values and then set the data frame to WGS 1984 and calc'ed those. I set NAD_1927_To_WGS_1984_79_CONUS as the transformation. The results differed as I expected.
Melita
JoeBorgione
Can you identify the local datum from which to transform it?  Unless you absolutely need sub-centimeter precision, I'd continue with your procedure...
That should just about do it....
ChrisDonohue__GISP
Sounds like something Melita Kennedy (ESRI staff/Projection-Coordinate System Guru (Guruess?)) could answer.
Chris Donohue, GISP
VinceAngelo
Esri Esteemed Contributor
I've always described Melita as the "High-Priestess of Projection"
MelitaKennedy
Lyndy,
Melita
