WinINet Error while using HTTPS security, 12030
48767
05-25-2020 09:24 AM
MercedesChinchilla
3 1 48.8K
Error 1
The connection with the server was terminated abnormally (WinINet Error while using HTTPS security, 12030), URL = https://domain:6443/arcgis/services
Error 2
Error executing tool. PublishServiceDefinition Job ID: jdbd97ffeeeeb4b7c89d92c92dfa8e08c : ERROR 001369: Failed to create the service. Failed to execute (Publish Service Definition).
Como resolver el error en ArcGIS Server:
Cambios en el IE.
1. On each machine hosting ArcGIS Server, log in as the ArcGIS Server account. This is the account running the ArcGIS Server service.
2. Click Start > Control Panel > Administrative Tools > Services and stop the ArcGIS Server service.
3. Click Start > Control Panel > Internet Options.
4. Click the Advanced tab and scroll down to the Security section.
5. Uncheck the option Check for server certificate revocation and click OK.
6. Click Start > Log off to log off the current user.
7. Log back in to the computer and start the ArcGIS Server service.
8. Repeat the
9. These steps on all other machines in your ArcGIS Server site.
Cambios en las políticas de seguridad.
Click Start > Run.
In the Open dialog box, type mmc and click OK.
Click File > Add/Remove Snap-in.
In the Add or Remove Snap-ins dialog box, choose the Group Policy Object Editor snap-in and click Add.
In the Select Group Policy Object dialog box, click Finish.
In the Add or Remove Snap-ins dialog box, click OK.
Under Console Root, expand Local Computer Policy > Computer Configuration > Windows Settings > Security Settings and choose Public Key Policies.
Under Object Type, double-click Certificate Path Validation Settings.
Click the Network Retrieval tab, and enable Define these policy settings.
Change the Default retrieval timeout settings values to 1 second.
Click OK.
Under Console Root, expand Local Computer Policy > Computer Configuration > Administrative Templates > System > Internet Communication Management and choose Internet Communication Settings.
Double-click Turn off Automatic Root Certificates Update and choose Enabled.
Click OK and close the console.
Tags (3)
1 Comment
About the Author
MSc in GIS & Geographer | GIS Analyst | ArcGIS Desktop Professional Certified | ArcGIS Geodata Associate Certified | Comptia CTT+
