We are monitoring issues that may have occurred as a result of the platform update.
If you are experiencing issues please let us know in Community Feedback . Once we are able to replicate the reported issue, we will update the community through this live document. Please subscribe to this document to be notified as soon as there are updates.
Date |
Known Issue |
Description |
Status |
11/12/20 | General styling issues - desktop and mobile | Minor styling issues of components on mobile and desktop views *My Profile page - issues viewing Safari |
Fixes ongoing |
11/13/2020 |
HTML error message |
Blog owners of migrated content reporting issues with Rich text editing and HTML error message preventing publishing or warning of formatting removal. |
Bug identified |
12/10/2020 |
Editing existing content e.g. blogs |
Deletion of white spaces is not being rendered correctly when publishing. For example: After creating a post (or reply) with a code block, whenever the post/reply is edited, an extra new line is added above and below the code block. This compounds with repeated edits. |
Fix released Dec 5, 2023 |
6/17/2021 |
Migrated code samples - display |
Code snippets are not displaying as expected to code language selected in posts and replies . |
Fix released Dec. 12, 2021 |
8/12/2021 |
Drag and drop when creating new posts and replies |
When dragging from an item from desktop/file explorer the upper target drop area does not function as expected.
Fix Released Oct 23. |
10/26/2021 |
Search Results Page - Places tabs |
When switching between the default Posts tab and the Places tab on a search results page with an existing search term the Places results list is not displaying. |
Fixed - monitoring |
02/02/2023 |
Private Message Notification |
The feature that sends email notifications to members who receive a Private Message in Esri Community isn’t working correctly. This is a known issue affecting Board level subscriptions: When subscribed to an entire Board, members will receive notifications for each new reply on Posts found in that Board. This happens even if their account preferences are set to only notify them of the first post in each topic (the default setting). To remedy this, consider subscribing to specific labels or Posts in those Boards instead of the Board itself This is different than the Subscription Notification emails, which are working. Workaround: Applies to all users and users do not have any option to turn off the PM notification. Workaround will NOT work at this time. Because of where it falls on Khoros prioritization list, we're anticipating that this will take some time to correct and don't have an ETA as of right now.
Fix release Dec 5, 2023
02/22/2023 |
Filter search results by language |
To allow for filtering search results by language when you search in Esri Community. For example, I searched the question forums for "arcgis api for python," and a very large portion of the search results were questions or posts that people wrote in Chinese or Japanese (because they had spelled "arcgis api for python" in English but the rest of their post was in another language), while I am only an English speaker. So the large proportion of posts in another language made it a lot less efficient for me to look through the search results. |
Future enhancement |
03/21/2023 |
Remove notifications when the user marks an answer as a solution |
If the user has an email notification turned on for accepted solutions. Unfortunately, the user also gets an email every time , they mark something as a solution on their own post. The user do not need an email to tell that they just marked something as a solution. It is very helpful to see when other posts have been resolved, but I don't need to know when mine have. Workaround 1: Turning off any notifications works best for some. Workaround 2: I created a custom rule in Microsoft Outlook to automatically delete those emails:
05/01/2023 |
Blank Space Issue |
With Community Blogs and Documents and layout? It is impossible to control spacing the way we want to. Spacing seems to get randomly added around graphics and code snippets. identified as a bug and will be fixed in the Aurora Release that is scheduled for end of this year. We received a final update from our Khoros engineering team. The issue is seen with TinyMCE version 4.x and this issue will not be seen in the new Aurora Release coming at end of the year. We have been told that this issue is not reproducible in Aurora as Aurora is built in TinyMCE version 5.10.
Bug Identified. Scheduled to get fix in Aurora Release. |
07/18/23 |
'Redirected too many times' issue |
Seeing a pattern of users reporting the ‘you’ve been redirected too many times’ message" Our platform vendor professional services is investigating the issue. No resolution yet. Workaround (This has worked for some users): 1) Please try accessing Esri Community via a private browser (incognito window) 2) Clear cache and cookies which both have been successful at clearing up the issue for others. 3) If they are using Edge go to the Clear Browsing History setting in Edge and found it was defaulted to clear only the last 24 hours and some of the things to clear were turned off by default. By changing the settings to clear All Time and turned on all the other things. |
Fixed Oct, 23 Update 08/09/23: We pushed a fix in production today Aug 9, 23 If you see this issue again, please clear cache and cookies once, so it implements the new fixes and try again. We are hopeful that users will not see this issue anymore. But if you see this issue again, could you please let me know. Thanks. Update on July 18th: Escalated and actively investigating |
10/25/24 |
Missing Avatar Issue |
The avatar images are broken link on Esri Community. |
10/24: Escalated and actively investigating 10/28: Reviewed on staging and trying some fixes today. 10/30: Resolved. Downgraded to 24.8 version. |
Date |
Known Issue |
Description |
Status |
11/12/20 | Navigation - megamenu | Tab switching after clicking an item from All Communities tab |
Fixed |
11/12/20 | ArcGIS Ideas - GeoNet, The Esri Community | Latest Activity Feed A-Z sort behavior unexpected and refresh takes user to top of page | Fixed |
11/12/20 | Special character issues | Various issues with & and special characters appearing in feeds on Profile Page. |
Fixed |
11/12/20 |
Wrong user attribute |
When viewing another users posts on Recent Posts Page Latest Contributions is displaying current logged in user |
Fixed |
11/12/20 |
View counts on board tiles |
Some board tiles displaying 0 for topic counts although board has content |
Fixed |
11/12/20 |
Unexpected error message 'Request Entity too Large' |
When replying to threads an unexpected error is seen. |
Fixed |
11/12/20 |
Threaded View Hides Replies |
When changing to Threaded layout, no replies show. |
Fixed |
11/12/2020 |
Replies to threads - text editor behavior |
When replying to a post the text editor displays one line and does not offer the expanded view. |
Fixed |
11/12/20 | Ideas Exchange boards - Filter by Idea Status |
After selecting a status there is no clear/view all option |
Fixed |
11/13/2020 |
Insert Code - lost formatting |
Insert code loses expected format between editing and publishing. |
Fixed |
11/13/2020 |
Migrated Code - lost formatting |
Migrated content pre Nov 12 not displaying content correctly in all content types |
Fixed |
11/14/2020 |
Badge count on profile page is off |
Badge count on profile page does not match total badges earned on view all badge page |
Fixed |
11/14/2020 |
View All Badges page - avatar menu behavior |
When viewing all badges earned from a Profile page the dropdown menu has lost it's stacked format. |
Fixed |
11/14/2020 |
Redirects |
Some redirects are not working as expected. This affects mostly archived content and JX pages that existed below a space or group e.g. /overview |
Fixed |
11/17/2020 |
Intermittent Attachment Virus Scan Not Completing |
Some members are seeing attached files on posts not completing the virus scan. |
Fixed |
11/18/2020 |
Private Message - Attachments |
Issues viewing and downloading attachments in Private messages in their original file format. |
Fixed |
12/8/2020 |
Flood controls |
Flood control messaging is being trigged after one or two attempts to publish a message. |
Fixed |
1/13/2021 |
Search terms using quotation marks |
Search results using quotation marks not working as expected |
Fixed |
1/13/2021 |
Links from email or Google not working 1st time |
Reported in this thread & this thread Dependent on your signed in status on esri.com sites links in notification emails or Google search results may result in the link clicked redirecting to Home page on first click but working 2nd time. |
Fixed |
1/29/2021 |
Ideas Posts - Label Display |
After adding a label to an Idea Post the published Idea does not display the Label chosen next to the expected place in the header. The label is still present when editing the post. |
Fixed |
1/30/2021 |
Load More - Activity Feeds |
When not logged the load more option and activity filters are not functioning normally. |
Fixed |
2/3/2021 |
Missing links |
For some historical posts links to other community content is missing |
Fixed |
2/4/2021 |
Avatar missing |
Due to recent avatar updates some users avatars have been removed and not auto replaced. |
Fixed |
2/8/2021 |
Profile Page - access or display issues |
For some users access or display of their profile page may be impaired due to a specific issue with their activity feed and items in archive. |
Fixed |
2/17/2021 |
About Author - Blogs |
Update: About Author component displays the author of the link being viewed. |
Fixed |
3/11/2021 |
Double page load |
On initial page load a brief flash occurs while the page loads |
Fixed |
4/16/2021 |
Missing boards and categories |
A select number of places and boards are missing from menus, search or landing pages although they still exist and their content is still searchable. |
Fixed |
4/16/2021 |
Missing comments on blogs |
Blog articles with comments may not show all indicated comments/ |
Fixed |
4/20/2021 |
Firefox/ Edge/ Chrome logout |
When navigating between Esri Community and other Esri websites the logged in account is being automatically logged out. |
Fixed |
4/30/2021 |
Leaderboards incorrect |
Leaderboards are showing incorrect numbers and order. |
Fixed |
5/3/2021 |
Products page- extra filter tabs |
Filter tabs from top level products page showing on all product places |
Fixed |
5/3/2021 |
All Worldwide communities link in main nav missing |
workaround: go to all communities, select worldwide from there to see all WW places until fix is deployed |
Fixed |
5/25/2021 |
Attachment preview not available |
Attachment preview will not be available for an estimated 12 hour window starting May 25 4pm PDT |
Maintenance Completed |
6/10/2021 |
Firefox - Products tab views |
The Core and Capabilites tabs on the Product page displays unexpected empty tiles when moving mouse focus between tiles. |
Fixed |
6/29/2021 |
Global menu - All Communities |
Clicking on the All Communities link is unexpectedly navigating to the All Communities page. Expected behavior should be dropdown menu launches and remains in view. |
Issue resolved - monitoring |
6/29/2021 |
Load more - Latest Activity feeds |
Load more is scrolling to the top of the page after clicking. Expected behavior should be the latest activity feed view is fixed to the location where load more was clicked. |
Previously requested enhancements section of the document has been replaced with Community Idea Exchange.
Reference
Related Idea | Enhancement | Description | Status |
Need Ability to remove tags |
Tag removals at a post level and found this can’t be done without deleting it from the Board/Place level entirely. |
Place managers and admins have the ability to remove tags, but this would be at the Place or Board level. For an example, if we were to remove the ArcMap equivalency tag from the below post (idea), anyone who has used the same tag in the same Place/Board would also have the tag removed from their post(s). We are hoping with future platform enhancements, we will have the ability to delete any tag from a post level without deleting the tag entirely from the Board/Place, but at this moment, it is not an option. |
Open |
Search results - filter options | Move the options to filter search results by unanswered posts from advanced search to a filter button alongside other Search results filter options | ||
Idea submission form improvement: label field as d... | Label Chooser experience | Improve the UI for searching, reviewing label descriptions and choosing labels to add to posted content | Open |
Arcade as option for the code sample | Code options - insert code | Adding Arcade as an option in list of languages | Open |
Update Behavior when Reply to Post | Reply to cursor placement | Suggestion to default to Reply body instead of Subject field | Open |
Latest Activity sort by | Add Sort by Most Recent Activity (e.g. comments/replies) Anchor link the Load more to where clicked rather than scroll to bottom on load Add Sort by Unresolved Posts (e.g. has a comment but not marked with an accepted solution) |
Mark posts as read setting | Mark as Read - manual | Will you add a manual "Mark posts as read" option? | Open |
Text editor - Size of body text field | When editing existing content have the body text window size default to fit the size of existing content instead of offering the drag handle. |
Filtering Content on the Community Home Page? | Latest activity feeds - sort by | Adding the ability to sort by unanswered posts in all activity feeds | Complete See details |
Hero banner height | Reduce the height of the hero banner on all place and board pages to promote content higher up the page | Completed. See details |
Code snippets - line numbers | Including line numbers automatically with posted code snippets | Complete | |
Other board tile navigation | On boards having the Other Boards in this Place widget be defaulted to collapse on page load. When landing on a board page the Other Boards listing at the top of the page is auto collapsed on page load. |
Complete | |
Text editor - Block quotes |
Applying these to any piece of content instead of current implementation where it references text in the post thread only. Feature now available in text editor known as BlockQuote which allows you to format any piece of text in a new post or reply as a block quote.
Complete | |
SQL missing from language list | Include SQL in available list of code languages | Request in this thread | Complete |
Remember language for code | Alphabetize available code language list | When choosing from the code insert options display list in alphabetical order | Complete |
Horizontal Scrollbar for Code Sample would improve... | Code samples - horizontal scroll bar | Requested in this thread | Complete |
photo upload working Leslie 😉
Hi @Anonymous User ,
I noticed that the link "Community Feedback" at the top of this document is still pointing to the staging environment. 😕
Thanks @XanderBakker I updated the link.
First off let me admin that I'm an old timer having working with ESRI products for over 30 years. When it comes to forums or communities I like to browse what people are posting about to try and see what's going out outside of my interests. This is when I'm not looking for help. I wasn't a fan of GeoNet and I'm not seeing the new system as an improvement.
Maybe it's because I always come to GeoNet on a computer and not a mobile device. I like to see more titles at a time and scroll less, both of which have increased with the new system. For me the most important items are Type (Post/Idea), Title, Community, and date. For me the Avatars are visual static that disturb quickly taking in the information plug there add to the amount of space that each listing takes up.
Below I have a screen shot illustrating how it looks and how it could be streamlined and highlighting the most important information! It's just an idea. But it would me nice if there were a streamlined interface alternative available. Thanks and I hope you don't mind the suggestion.
I'm not sure the entirety of the discussion for "Label Chooser experience: Improve the UI for searching, reviewing label descriptions and choosing labels to add to posted content". But an initial reaction in our organization was that it would be nice to at least have an option to limit label choices to those recognized within our organization's place and not forum-wide.
Hi @Anonymous User and @Anonymous User ,
Do you know if there are any issues with private messaging?
I received a private message with an attachment (a ZIP with data to test with) and when I hover over the download button it seems to link to a ZIP file:
However, when I click on the button it downloads an html file (and not the ZIP with data):
Also trying to reply to this message resulted in an error:
Any ideas?
@XanderBakker Yes there is a known issue with attachments on private messages where it's not downloading the file type in the right file type and is defaulting to .html. We raised this as a high priority support ticket and I had yet to add it above so will do this right now.
Thanks @Anonymous User !
How can I see the appropriate labels to use when posting a question? Specifically, I'm trying post a question under the Geoprocessing community. The Labels box is blank and I don't know what to put here. This is preventing me from posting my question and engaging with the community.
I think when I posted in the ArcGIS Pro community, it listed some possible labels. This would be useful to see for every community I try to post to.
Thanks!
hi @tigerwoulds Not all the places have pre-defined labels. If there are no labels to select from then there are not currently any pre-defined for that place, and you can leave the field blank. In the case of Geoprocessing, there are currently no labels setup, so in this case leave the field blank. But you can add tags. Hope that helps.
Cheers
Hello again - I still do not know how to control the notifications feed. Before the platform update this month, I only saw notifications in my notification feed for posts that I either generated or posts that I replied to. Now, my feed contains every reply from every user for every topic that I am subscribed to.
Help! Information Overload!
Wow nice
Has this list been abandoned? Seems like the last update was in Dec 2023.
