Retrieve EVA License
267
10-21-2021 07:49 AM
wsmgis2021
I had arcgis installed on my pc I needed to format it but I didn't remove the authorization before, to reinstall later.
Now that I've installed the operating system again, and I've also installed ArcGIS, I can't authorize ArcGIS again with the EVA license.
So I ask if there is a way to reinstall ArcGIS with this EVA license without it having been deauthorized before. The EVA license is valid until August 2022.
JayantaPoddar
MVP Esteemed Contributor
Reaching out to your local Esri Support / distributor seems to be the only way to deal with it. You may need a new code to work with, if the current EVA code can't be reset.
Think Location
wsmgis2021
Thank you so much JayantaPoddar, I will do as you recommended.
