Failed to Execute GPX to Features
1407
10-06-2021 12:47 PM
Rubicon
I am trying to run the "GPX to Features" tool in ArcMap 10.8 to convert tracks from a handheld Garmin device, but I keep getting the following error:
File "c:\program files (x86)\arcgis\desktop10.8\ArcToolbox\Scripts\GPXtoFeatures.py", line 260, in <module>
gpxToPoints(gpx, outFC)
File "c:\program files (x86)\arcgis\desktop10.8\ArcToolbox\Scripts\GPXtoFeatures.py", line 36, in gpxToPoints
tree = ElementTree.parse(gpxfile)
File "<string>", line 62, in parse
File "<string>", line 38, in parse
ParseError: unbound prefix: line 1, column 1085
Failed to execute (GPXtoFeatures).
This seems like an issue with the script for the tool itself, which I have not edited. I am using the tool "as is" from the default toolboxes in ArcMap. I use this tool often and it worked a few days ago. I am not familiar with Python.
What does this error mean and what can I do to fix it?
DuncanHornby
MVP Notable Contributor
It's possible that the GPX file is in some way corrupted? I would try a new GPX file created on you Garmin. Walk around outside for a minute capture a track then try and import that.
DuncanHornby
Rubicon
The tool worked on other GPX files from different Garmin devices, so I think you are right that it was corrupted.
