Hello,
I have a web application that contains several different layer types including feature layers, map image layers, and hosted feature layers. In the "layers" widget settings, I have enabled users to update the visible scale range for each layer. However, when I launch the application and attempt to do that, the visibility range doesn't change.
Originally some of the layers were published with a visible scale range applied, so I thought that was the issue. However I re-published the data with no visible scale range set, and the problem persists.
Does anyone know if this is a bug or have any idea why I might not have this capability, even though it's enabled in the app/layer settings?
Thank you,
Tara
