reorder attribute table fields
565
09-24-2021 08:44 AM
ChrisD
New Contributor III
Hello there,
Is it possible to reorder attribute table fields in a Web Appbuilder app? I can reorder the fields as they display in the popup window, but that apparently doesn't apply to the attribute table and the fields are just sorted alphabetically. Any help would be much appreciated.
Chris
EmmaHatcher
Also running into that problem. This would be a helpful capability in Web AppBuilder!
Oliver_Burdekin
Occasional Contributor II
Yes, you need to use the attribute table widget in web app builder to reorder the fields. In the editing view of your app edit the attribute table widget, then use the pencil in the "configure fields" section to edit the order (and aliases) of your fields. You can also set the visibility.
