Hello
I need some help in the drawing widget for experience builder. How can the end user save and share the sketch with other users?
Thank you for raising this query.
You can add the Print Widget to generate an output that can be shared with other users.
Hope this helps.
Hi Michelle
Thank you for the response. This however is not saving the sketch for future reference, on the map for future reference. We have to do re create the same sketch every time.
Is there an other solution that could save, export and re share the sketch?
