David,
OK, then here is the whole file with my changes for option 2:
_onSelectResult lines 763 - 769 are the important new changes for 2.6 (commenting these lines).
define([
'dojo/_base/declare',
'dojo/_base/lang',
'dojo/_base/array',
'dojo/_base/html',
'dojo/when',
'dojo/on',
'dojo/aspect',
'dojo/query',
'dojo/keys',
'dojo/Deferred',
'dojo/promise/all',
'jimu/BaseWidget',
'jimu/LayerInfos/LayerInfos',
'jimu/utils',
'esri/dijit/Search',
'esri/tasks/locator',
'esri/layers/FeatureLayer',
'esri/InfoTemplate',
'esri/lang',
'./utils',
'esri/symbols/jsonUtils',
'dojo/NodeList-dom'
function(declare, lang, array, html, when, on, aspect, query, keys, Deferred, all,
BaseWidget, LayerInfos, jimuUtils, Search, Locator,
FeatureLayer, InfoTemplate, esriLang, utils, jsonUtils) {
return declare([BaseWidget], {
baseClass: 'jimu-widget-search',
searchDijit: null,
searchResults: null,
_startWidth: null,
postCreate: function() {
if (this.closeable || !this.isOnScreen) {
html.addClass(this.searchNode, 'default-width-for-openAtStart');
this.listenWidgetIds.push('framework');
startup: function() {
this.inherited(arguments);
if (!(this.config && this.config.sources)) {
this.config.sources = [];
LayerInfos.getInstance(this.map, this.map.itemInfo)
.then(lang.hitch(this, function(layerInfosObj) {
this.layerInfosObj = layerInfosObj;
this.own(this.layerInfosObj.on(
'layerInfosFilterChanged',
lang.hitch(this, this.onLayerInfosFilterChanged)));
utils.setMap(this.map);
utils.setLayerInfosObj(this.layerInfosObj);
utils.setAppConfig(this.appConfig);
when(utils.getConfigInfo(this.config)).then(lang.hitch(this, function(config) {
return all(this._convertConfig(config)).then(function(searchSouces) {
return array.filter(searchSouces, function(source) {
return source;
})).then(lang.hitch(this, function(searchSouces) {
if (!this.domNode) {
return;
this.searchDijit = new Search({
activeSourceIndex: searchSouces.length === 1 ? 0 : 'all',
allPlaceholder: jimuUtils.stripHTML(esriLang.isDefined(this.config.allPlaceholder) ?
this.config.allPlaceholder : ""),
autoSelect: true,
enableButtonMode: false,
enableLabel: false,
enableInfoWindow: true,
enableHighlight: esriLang.isDefined(this.config.showInfoWindowOnSelect) ?
!!this.config.showInfoWindowOnSelect : true,
showInfoWindowOnSelect: esriLang.isDefined(this.config.showInfoWindowOnSelect) ?
map: this.map,
sources: searchSouces,
theme: 'arcgisSearch'
html.place(this.searchDijit.domNode, this.searchNode);
this.searchDijit.startup();
this._resetSearchDijitStyle();
this.own(
this.searchDijit.watch(
'activeSourceIndex',
lang.hitch(this, '_onSourceIndexChange')
this.own(
on(this.searchDijit.domNode, 'click', lang.hitch(this, '_onSearchDijitClick'))
this.own(on(this.searchDijit.inputNode, "keyup", lang.hitch(this, function(e) {
if (e.keyCode !== keys.ENTER) {
this._onClearSearch();
this.own(
aspect.before(this.searchDijit, 'select', lang.hitch(this, '_captureSelect'))
this.own(
on(this.searchDijit, 'search-results', lang.hitch(this, '_onSearchResults'))
this.own(
on(this.searchDijit, 'suggest-results', lang.hitch(this, '_onSuggestResults'))
this.own(
on(this.searchDijit, 'select-result', lang.hitch(this, '_onSelectResult'))
this.own(
aspect.before(this.map.infoWindow, 'setFeatures', lang.hitch(this, '_attatchOriLayerId'))
this._mapInfoWindow_ = this.map.infoWindow;
var _winResizeHandler = on(window, 'resize', lang.hitch(this, function() {
if (this._mapInfoWindow_ !== this.map.infoWindow) {
this.own(
_winResizeHandler.remove();
this.own(
on(this.searchResultsNode, 'li:click', lang.hitch(this, '_onSelectSearchResult'))
this.own(on(
'.show-all-results:click',
lang.hitch(this, '_showResultMenu')
this.own(
on(window.document, 'click', lang.hitch(this, function(e) {
if (!html.isDescendant(e.target, this.searchResultsNode)) {
this._hideResultMenu();
this._resetSelectorPosition('.show-all-results');
this.own(
on(this.searchDijit, 'clear-search', lang.hitch(this, '_onClearSearch'))
this.own(
aspect.after(this.map.infoWindow, 'show', lang.hitch(this, function() {
if (this.searchDijit &&
this.map.infoWindow.getSelectedFeature() !==
this.searchDijit.highlightGraphic) {
query('li', this.searchResultsNode).removeClass('result-item-selected');
this.fetchData('framework');
onReceiveData: function(name, widgetId, data) {
if (name === 'framework' && widgetId === 'framework' && data && data.searchString) {
this.searchDijit.set('value', data.searchString);
this.searchDijit.search();
setPosition: function(position) {
this._resetSearchDijitStyle(position);
resize: function() {
onLayerInfosFilterChanged: function(changedLayerInfos) {
array.some(changedLayerInfos, lang.hitch(this, function(info) {
if (this.searchDijit && this.searchDijit.sources && this.searchDijit.sources.length > 0) {
array.forEach(this.searchDijit.sources, function(s) {
if (s._featureLayerId === info.id) {
s.featureLayer.setDefinitionExpression(info.getFilter());
_resetSearchDijitStyle: function() {
html.removeClass(this.domNode, 'use-absolute');
if (this.searchDijit && this.searchDijit.domNode) {
html.setStyle(this.searchDijit.domNode, 'width', 'auto');
setTimeout(lang.hitch(this, function() {
var box = {
w: !window.appInfo.isRunInMobile ? 274 :
parseInt(html.getComputedStyle(this.domNode).width, 10)
var sourcesBox = html.getMarginBox(this.searchDijit.sourcesBtnNode);
var submitBox = html.getMarginBox(this.searchDijit.submitNode);
var style = null;
if (box.w) {
html.setStyle(this.searchDijit.domNode, 'width', box.w + 'px');
html.addClass(this.domNode, 'use-absolute');
if (isFinite(sourcesBox.w) && isFinite(submitBox.w)) {
if (window.isRTL) {
style = {
left: submitBox.w + 'px',
right: sourcesBox.w + 'px'
} else {
style = {
left: sourcesBox.w + 'px',
right: submitBox.w + 'px'
var inputGroup = query('.searchInputGroup', this.searchDijit.domNode)[0];
if (inputGroup) {
html.setStyle(inputGroup, style);
var groupBox = html.getMarginBox(inputGroup);
var extents = html.getPadBorderExtents(this.searchDijit.inputNode);
html.setStyle(this.searchDijit.inputNode, 'width', groupBox.w - extents.w + 'px');
}), 50);
_convertConfig: function(config) {
var sourceDefs = array.map(config.sources, lang.hitch(this, function(source) {
var def = new Deferred();
if (source && source.url && source.type === 'locator') {
var _source = {
locator: new Locator(source.url || ""),
outFields: ["*"],
singleLineFieldName: source.singleLineFieldName || "",
name: jimuUtils.stripHTML(source.name || ""),
placeholder: jimuUtils.stripHTML(source.placeholder || ""),
countryCode: source.countryCode || "",
maxSuggestions: source.maxSuggestions,
maxResults: source.maxResults || 6,
zoomScale: source.zoomScale || 50000,
useMapExtent: !!source.searchInCurrentMapExtent
if (source.enableLocalSearch) {
_source.localSearchOptions = {
minScale: source.localSearchMinScale,
distance: source.localSearchDistance
def.resolve(_source);
} else if (source && source.url && source.type === 'query') {
var searchLayer = new FeatureLayer(source.url || null, {
outFields: ["*"]
this.own(on(searchLayer, 'load', lang.hitch(this, function(result) {
var flayer = result.layer;
var template = this._getInfoTemplate(flayer, source, source.displayField);
var fNames = null;
if (source.searchFields && source.searchFields.length > 0) {
fNames = source.searchFields;
} else {
fNames = [];
array.forEach(flayer.fields, function(field) {
if (field.type !== "esriFieldTypeOID" && field.name !== flayer.objectIdField &&
field.type !== "esriFieldTypeGeometry") {
fNames.push(field.name);
var convertedSource = {
featureLayer: flayer,
outFields: ["*"],
searchFields: fNames,
displayField: source.displayField || "",
exactMatch: !!source.exactMatch,
maxSuggestions: source.maxSuggestions || 6,
infoTemplate: template,
useMapExtent: !!source.searchInCurrentMapExtent,
_featureLayerId: source.layerId
if(source.highlightSymbol){
convertedSource.highlightSymbol = jsonUtils.fromJson(source.highlightSymbol);
if (!template) {
delete convertedSource.infoTemplate;
if (convertedSource._featureLayerId) {
var layerInfo = this.layerInfosObj
.getLayerInfoById(convertedSource._featureLayerId);
flayer.setDefinitionExpression(layerInfo.getFilter());
def.resolve(convertedSource);
this.own(on(searchLayer, 'error', function() {
def.resolve(null);
} else {
def.resolve(null);
return def;
return sourceDefs;
_getInfoTemplate: function(fLayer, source, displayField) {
var layerInfo = this.layerInfosObj.getLayerInfoById(source.layerId);
var template = layerInfo && layerInfo.getInfoTemplate();
var validTemplate = layerInfo && template;
if (layerInfo && !validTemplate) {
return null;
} else if (validTemplate) {
return template;
} else {
template = new InfoTemplate();
template.setTitle(' ');
template.setContent(
lang.hitch(this, '_formatContent', source.name, fLayer, displayField)
return template;
_getSourcePopupInfo: function(source) {
if (source._featureLayerId) {
var layerInfo = this.layerInfosObj.getLayerInfoById(source._featureLayerId);
if (layerInfo) {
return layerInfo.getPopupInfo();
return null;
_captureSelect: function(e) {
var sourceIndex = this.searchDijit.activeSourceIndex;
if (sourceIndex === 'all') {
sourceIndex = this._getSourceIndexOfResult(e);
if (isFinite(sourceIndex) && esriLang.isDefined(sourceIndex)) {
this._currentSelectSourceIdx = sourceIndex;
var source = this.searchDijit.sources[sourceIndex];
if (source && 'featureLayer' in source) {
var popupInfo = this._getSourcePopupInfo(source);
var notFormatted = (popupInfo && popupInfo.showAttachments) ||
(popupInfo && popupInfo.description &&
popupInfo.description.match(/http(s)?:\/\//)) ||
(popupInfo && popupInfo.mediaInfos && popupInfo.mediaInfos.length > 0);
if (!e.feature.__attributes) {
e.feature.__attributes = e.feature.attributes;
if (!notFormatted) {
var formatedAttrs = this._getFormatedAttrs(
lang.clone(e.feature.attributes),
source.featureLayer.fields,
source.featureLayer.typeIdField,
source.featureLayer.types,
popupInfo
e.feature.attributes = formatedAttrs;
return [e];
_getSourceIndexOfResult: function(e) {
if (this.searchResults){
for (var i in this.searchResults) {
var sourceResults = this.searchResults[i];
var pos = array.indexOf(sourceResults, e);
if (pos > -1) {
return parseInt(i, 10);
return null;
_formatContent: function(title, fLayer, displayField, graphic) {
var content = "";
if (graphic && graphic.attributes && fLayer && fLayer.url) {
var aliasAttrs = {};
array.forEach(fLayer.fields, lang.hitch(this, function(field) {
if (field.name in graphic.attributes){
aliasAttrs[field.alias || field.name] = graphic.attributes[field.name];
var displayValue = graphic.attributes[displayField];
content += '<div class="esriViewPopup">' +
'<div class="mainSection">' +
(esriLang.isDefined(displayValue) ?
('<div class="header">' + title + ': ' + displayValue + '</div>') : "") +
'<div class="hzLine"></div>' +
'<div>' +
'<table class="attrTable" cellpading="0" cellspacing="0">' +
'<tbody>';
for (var p in aliasAttrs) {
if (aliasAttrs.hasOwnProperty(p)) {
content += '<tr valign="top">' +
'<td class="attrName">' + p + '</td>' +
'<td class="attrValue">' + aliasAttrs[p] + '</td>' +
'</tr>';
content += '</tbody>' +
'</table>' +
'</div>' +
'<div class="break"></div>' +
'</div>';
return content;
_getFormatedAttrs: function(attrs, fields, typeIdField, types, popupInfo) {
function getFormatInfo(fieldName) {
if (popupInfo && esriLang.isDefined(popupInfo.fieldInfos)) {
for (var i = 0, len = popupInfo.fieldInfos.length; i < len; i++) {
var f = popupInfo.fieldInfos[i];
if (f.fieldName === fieldName) {
return f.format;
return null;
array.forEach(fields, lang.hitch(this, function(_field, i) {
if (!attrs[_field.name]) {
return;
var isCodeValue = !!(_field.domain && _field.domain.type === 'codedValue');
var isDate = _field.type === "esriFieldTypeDate";
var isTypeIdField = typeIdField && (_field.name === typeIdField);
var fieldAlias = _field.name;
if (fields[i].type === "esriFieldTypeDate") {
aliasAttrs[fieldAlias] = jimuUtils.fieldFormatter.getFormattedDate(
attrs[_field.name], getFormatInfo(_field.name)
} else if (fields[i].type === "esriFieldTypeDouble" ||
fields[i].type === "esriFieldTypeSingle" ||
fields[i].type === "esriFieldTypeInteger" ||
fields[i].type === "esriFieldTypeSmallInteger") {
aliasAttrs[fieldAlias] = jimuUtils.fieldFormatter.getFormattedNumber(
if (isCodeValue) {
aliasAttrs[fieldAlias] = jimuUtils.fieldFormatter.getCodedValue(
_field.domain, attrs[_field.name]
} else if (isTypeIdField) {
aliasAttrs[fieldAlias] = jimuUtils.fieldFormatter.getTypeName(
attrs[_field.name], types
} else if (!isCodeValue && !isDate && !isTypeIdField) {
aliasAttrs[fieldAlias] = fieldAlias in aliasAttrs ?
aliasAttrs[fieldAlias] : attrs[_field.name];
aliasAttrs[fieldAlias] = this.getCodeValueFromTypes(
_field,
typeIdField,
types,
attrs,
aliasAttrs
return aliasAttrs;
getCodeValueFromTypes: function(field, typeIdField, types, obj, aliasAttrs) {
var codeValue = null;
if (typeIdField && types && types.length > 0) {
var typeChecks = array.filter(types, lang.hitch(this, function(item) {
return item.name === obj[typeIdField];
var typeCheck = (typeChecks && typeChecks[0]) || null;
if (typeCheck && typeCheck.domains &&
typeCheck.domains[field.name] && typeCheck.domains[field.name].codedValues) {
codeValue = jimuUtils.fieldFormatter.getCodedValue(
typeCheck.domains[field.name],
obj[field.name]
var fieldAlias = field.name;
var _value = codeValue !== null ? codeValue : aliasAttrs[fieldAlias];
return _value || isFinite(_value) ? _value : "";
_resetSelectorPosition: function(cls) {
var layoutBox = html.getMarginBox(window.jimuConfig.layoutId);
query(cls, this.domNode).forEach(lang.hitch(this, function(menu) {
var menuPosition = html.position(menu);
if (html.getStyle(menu, 'display') === 'none') {
return;
var dijitPosition = html.position(this.searchDijit.domNode);
var up = dijitPosition.y - 2;
var down = layoutBox.h - dijitPosition.y - dijitPosition.h;
if ((down > menuPosition.y + menuPosition.h) || (up > menuPosition.h)) {
html.setStyle(
menu,
'top',
(down > menuPosition.y + menuPosition.h) ?
dijitPosition.h : -menuPosition.h - 2
) + 'px'
} else {
html.setStyle(menu, 'height', Math.max(down, up) + 'px');
html.setStyle(menu, 'top', (down > up ? dijitPosition.h : -up - 2) + 'px');
_onSourceIndexChange: function() {
if (this.searchDijit.value) {
this.searchDijit.search(this.searchDijit.value);
_onSearchDijitClick: function() {
this._resetSelectorPosition('.searchMenu');
_onSearchResults: function(evt) {
var sources = this.searchDijit.get('sources');
var activeSourceIndex = this.searchDijit.get('activeSourceIndex');
var value = this.searchDijit.get('value');
var htmlContent = "";
var results = evt.results;
var _activeSourceNumber = null;
if (results && evt.numResults > 0) {
html.removeClass(this.searchDijit.containerNode, 'showSuggestions');
this.searchResults = results;
htmlContent += '<div class="show-all-results jimu-ellipsis" title="' +
this.nls.showAll + '">' +
this.nls.showAllResults + '<strong >' + value + '</strong></div>';
htmlContent += '<div class="searchMenu" role="menu">';
for (var i in results) {
if (results[i] && results[i].length) {
var name = sources[parseInt(i, 10)].name;
if (sources.length > 1 && activeSourceIndex === 'all') {
htmlContent += '<div title="' + name + '" class="menuHeader">' + name + '</div>';
htmlContent += "<ul>";
var partialMatch = value;
var r = new RegExp("(" + partialMatch + ")", "gi");
var maxResults = sources[i].maxResults;
for (var j = 0, len = results[i].length; j < len && j < maxResults; j++) {
var text = esriLang.isDefined(results[i][j].name) ?
results[i][j].name : this.nls.untitled;
htmlContent += '<li title="' + text + '" data-index="' + j +
'" data-source-index="' + i + '" role="menuitem" tabindex="0">' +
text.toString().replace(r, "<strong >$1</strong>") + '</li>';
htmlContent += '</url>';
if (evt.numResults === 1) {
_activeSourceNumber = i;
htmlContent += "</div>";
this.searchResultsNode.innerHTML = htmlContent;
this._showResultMenu();
} else {
this.publishData({
'searchResults': evt
_onSuggestResults: function(evt) {
this.publishData({
'suggestResults': evt
_onSelectSearchResult: function(evt) {
var target = evt.target;
while(!(html.hasAttr(target, 'data-source-index') && html.getAttr(target, 'data-index'))) {
target = target.parentNode;
var result = null;
var dataSourceIndex = html.getAttr(target, 'data-source-index');
var dataIndex = parseInt(html.getAttr(target, 'data-index'), 10);
if (dataSourceIndex !== 'all') {
dataSourceIndex = parseInt(dataSourceIndex, 10);
if (this.searchResults && this.searchResults[dataSourceIndex] &&
this.searchResults[dataSourceIndex][dataIndex]) {
result = this.searchResults[dataSourceIndex][dataIndex];
this.searchDijit.clearGraphics();
this.searchDijit.select(result);
_onSelectResult: function(e) {
var result = e.result;
if (!(result && result.name)) {
return;
var dataSourceIndex = e.sourceIndex;
var sourceResults = this.searchResults[dataSourceIndex];
var dataIndex = 0;
for (var i = 0, len = sourceResults.length; i < len; i++) {
if (jimuUtils.isEqual(sourceResults[i], result)) {
dataIndex = i;
break;
.forEach(lang.hitch(this, function(li) {
html.removeClass(li, 'result-item-selected');
var title = html.getAttr(li, 'title');
var dIdx = html.getAttr(li, 'data-index');
var dsIndex = html.getAttr(li, 'data-source-index');
if (title === result.name &&
dIdx === dataIndex.toString() &&
dsIndex === dataSourceIndex.toString()) {
html.addClass(li, 'result-item-selected');
this.publishData({
'selectResult': e
_attatchOriLayerId: function(fs) {
if (fs && fs.length && fs[0].declaredClass === "esri.Graphic" &&
esriLang.isDefined(this._currentSelectSourceIdx)) {
fs.forEach(lang.hitch(this, function(item) {
if (item.declaredClass === "esri.Graphic") {
var _featureLayerId = this.searchDijit.sources[this._currentSelectSourceIdx]._featureLayerId;
var layer = _featureLayerId && this.layerInfosObj.getLayerInfoById(_featureLayerId);
if (layer && this.config.showInfoWindowOnSelect) {
lang.setObject("_wabProperties.referToFeatureLayerId", _featureLayerId, item);
_onClearSearch: function() {
html.setStyle(this.searchResultsNode, 'display', 'none');
this.searchResultsNode.innerHTML = "";
this.searchResults = null;
_hideResultMenu: function() {
query('.show-all-results', this.searchResultsNode).style('display', 'block');
query('.searchMenu', this.searchResultsNode).style('display', 'none');
_showResultMenu: function() {
html.setStyle(this.searchResultsNode, 'display', 'block');
query('.show-all-results', this.searchResultsNode).style('display', 'none');
query('.searchMenu', this.searchResultsNode).style('display', 'block');
var groupNode = query('.searchInputGroup', this.searchDijit.domNode)[0];
if (groupNode) {
var groupBox = html.getMarginBox(groupNode);
var style = {
width: groupBox.w + 'px'
if (window.isRTL) {
var box = html.getMarginBox(this.searchDijit.domNode);
style.right = (box.w - groupBox.l - groupBox.w) + 'px';
} else {
style.left = groupBox.l + 'px';
query('.show-all-results', this.searchResultsNode).style(style);
query('.searchMenu', this.searchResultsNode).style(style);
destroy: function() {
utils.setMap(null);
utils.setLayerInfosObj(null);
utils.setAppConfig(null);
if (this.searchDijit) {
this.searchDijit.clear();
_hidePopup: function() {
if (this.map.infoWindow.isShowing) {
this.map.infoWindow.hide();
onActive: function() {
this._mapClickHandle = aspect.before(this.map, 'onClick', lang.hitch(this, function() {
this._hidePopup();
return arguments;
onDeActive: function() {
if (this._mapClickHandle && this._mapClickHandle.remove) {
this._mapClickHandle.remove();
this._hidePopup();
