Hi Kevin,
Yes, trying to access the Coordinate Conversion widget through the jsapi 4.18. I did get it to work by pointing to our geometry service with the line
esriConfig.geometryUrl="our url";
Works! Converts coordinates fine, but web console keeps giving me an error message "failed to load the projection module".
It references esri.widgets.CoordinateConversion.CoordinateConversionViewModel in the error.
Any idea why? I tried adding the projection module in the require section but get the same error.
I'm also getting a bunch of web assembly errors: "async and sync fetching of the wasm failed". Those errors multiply when I try using 4.21 and the data never displays on the map.
Any help or suggestions will be appreciated. Reminder that we're on Portal v10.8 in a closed system setting if that may be a factor.
