PopUps wont, um, pop-up...
2807
10-01-2014 09:23 AM
matthewweber
New Contributor III
I cannot get the PopUp to work in my Flex application. The features appear/render just fine. They consist of ~20,000 points  that represent mile markers found along the side of the highway. I have set the service to show more than the default 1000 features. Maybe a second set of eyes can spot something that is off? I'm the only GIS analyst here who knows anything about .xml/Flex, so I'm on my own.
Thanks everyone!
Here is the code from the config.xml:
<layer label="vPM" type="dynamic" visible="true" alpha="1.0"
  url="http://xxx.xxx.xxx/ArcGIS/rest/services/SWITRS_vPM_10/MapServer"
  popupconfig="popups/PopUp_vPM.xml"/>
And from the PopUp_vPM.xml:
<?xml version="1.0" ?>
<configuration>
    <title>Virtual Paddle Marker</title>
    <fields>
        <field name="C8_Name" visible="true"/>
        <field name="Lat" visible="true"/>
        <field name="Long" visible="true"/>
    </fields>
</configuration>
Tags (3)
RobertScheitlin__GISP
Matthew,
  Your configuration for your dynamic layer is incorrect.
  url="http://xxx.xxx.xxx/ArcGIS/rest/services/SWITRS_vPM_10/MapServer">
     <sublayer id="0" popupconfig="popups/PopUp_vPM.xml"/>
</layer>
and set the sublayer id attribute to the specific sublayer of your mapservice that the popup is for.
Matthew,
</layer>
matthewweber
New Contributor III
I'm sure you already know this Mr. Scheitlin, but you are awesome. Thanks for being king of the Flex forum!
One note/question though, I have never set the sublayer id for a dynamic service before. I have set things up like this...
<layer label="Line Beats" type="feature" visible="false" alpha="1" url=xxx.xxx.xxx/ArcGIS/rest/services/CCCT_Dev_GISSU/FeatureServer/0" popupconfig="popups/PopUp_Line_Beats.xml" />
...where I have the order of the features set directly (in this case ".../Feature/0"). Is the <sublayer> only necessary for dynamic layers?
Matthew,
   Correct sublayers are for dynamiclayers. When you use a a feature type you actually specify the sub layer in the url so there is no need for this.
