Hi Agnieszka,
Thank you for your answer.
That make a lot of sense. I understand the roll back is on failure and 504 is not necessary a failure, most of the time it will be a success.
As the timeout is not defined at the client level, but in the API server, I cannot increase the timeout value, right? Is there a possibility to make async requests that wont timeout?
From what I understand, in case of 504, the only way I can know if the parcels were created or not is to make a query to the database and check if those parcels exist?
Thank you again for your time with my questions.
Best regards,
Maxime Demers
