I have wrapped up a data collection project and am now looking at the reporting functions. The sample reports were decent and worked fine, including a map. However I wanted to change the format as well as adjust the map itself using my own template.
I found that I am unable to create a report with a map using $location or $shape. Neither an unmodified template or an otherwise empty document with "${location}" work.
Any ideas what could be causing the error?
An error occurred when rendering by the report engine. Failed to print map for ${location|mapSettings:"---------------------------------”:1000| size:600:600}. Error: Failed to print map: {"name":"request:server","message":"Error","details":{"url":"-------------------------------------","requestOptions":{"query":{"f":"json","returnExtentOnly":true,"returnCountOnly":true,"objectIds":"66","spatialRel":"esriSpatialRelIntersects"},"responseType":"json"},"ssl":false,"httpStatus":400,"messages":["This operation is not supported."],"raw":{"code":400,"message":"","details":["This operation is not supported."]}}}
