Survey123 Reports - Aerial Background in site map
374
09-28-2021 07:51 AM
MarkForsyth
I have a team of people including myself running reports on around 1,000 records.  One of my users' map background has suddenly turned to the Aerial map instead of the default map.  I run the report and get the default map but when they run it they get the aerial.
MarkForsyth
To be clear the background changes when she exports a report into word.
Location: ${location}  outputs with an aerial basemap.  When I export the exact same report I get the default map background.  Client does not want the aerial so we need to figure this out so she can run reports.
DerrickWestoby
I think it uses your organization default if you don't set it in the feature report template.
Save a web map with the display you want in the report, then copy the Item ID from the URL and add it to your ${location} field in the feature report template.  Make sure to share it with your other coworkers that are using the same report template, or just share it with "everyone".
Ex:
${geopoint | mapSettings:" b2519fd7a45647a0946f50b0535b6ddd ":6000| size:225:250:0:0}
