Survey123 HTML commands showing in heading text
1577
09-30-2021 10:23 AM
JeremiahJones
New Contributor II
My HTML commands for style options are showing up in my published survey. I am using survey123 connect to build this survey. This was not an issue 2 weeks ago. Is this a bug now?
JeremiahJones_1-1633022549555.png What it looks like in xlsx form
JeremiahJones_0-1633022504494.pngWhat appears in the survey
JasonCyphers
Occasional Contributor III
Try <p style="text-align:center">, and use </p> to close it.
JasonCyphers
JeremiahJones
New Contributor II
This works, it is just annoying that my previous solution stopped working. Thank you!
DougBrowning
MVP Esteemed Contributor
LeonardBarnhill
Due to the big update DougBrowning mentions, the solution mentioned will probably not work when you upgrade Survey123 to version 3.13.xxx.  Before you update to the current release, read the link from DougBrowning so you know how to use the new HTML formatting codes
