Hello! So we had some field personal bring a device back and claimed the app suddenly began to look distorted. I tried repairing, resetting, and even reinstalling the application and nothing has seemed to fix the issue. I took a look at the settings in the app itself and in Windows and everything appears normal. I do not think it is a settings issue because when you make a selection with the mouse it selects the item where it typically would be, however as you can see from the attached picture, it does not correspond to the window. The distortion is not present with any other application.
Any ideas??
