I'm attempting to create and publish a survey through Survey123 and upon completing a test version of the new survey, I attempt to publish it and I get the following error code with no further explanation:
{"code":-1,"message":""}
After searching google and geonet, I wasn't able to come up with what exactly this error means. All of the other examples of errors like this that I have seen have additional information in the error code( for example: {"code":-1,"message":"","isTrusted":true} .
I have tried the following solutions but still get the same error:
- Reload the webpage
- try in a different browser
- sign out and then sign back in
- restart the computer
*UPDATE* - I deleted the problem survey and started back over from scratch and I was able to publish the survey. However, I'm still curious to see if anyone knows why it failed in the first place and what that seemingly non-descriptive error code actually means so that I can avoid it in the future.
