Select one and return a value on a box
390
08-05-2022 07:53 AM
Luwerli
Hi!
The context: I have a question, of the select one type, that shows a box to put numbers on it if I have answered 'yes'. If I have answered the question as 'no', the box doesn't show. So the line of the column of numbers is empty if I have answered 'no' on the previous question.
My problem is that I need the column of numbers to be filled with 0 if the previous question was answered 'no'.
survey:
the table:
Katie_Clark
MVP Regular Contributor
Would it work to have the number of columns question set to have a default value of 0?
Best,
Katie
“The goal is not simply to ‘work hard, play hard.’ The goal is to make our work and our play indistinguishable.”
- Simon Sinek
Luwerli
Hi Katherine!
So I've tried this before and it didn't work. When I press the button 'no', the box that I should put the numbers doesn't show. It only shows up when I press the button 'yes'. That's why I think it's something more complicated than that.
but thank you anyway! I'll keep trying here
DougBrowning
Use the esri visible column vs relevant.  Relevant always stores as blank or null if not used.  Then as stated set the default to 0 and it should work.
Hope that helps
