Hello,
I am using a custom url to launch a Survey123 Form from a list in Dashboard. I created the Survey123 Form in Connect and I have "Require update to the latest version of this survey" checked. However, when it opens the Survey123 Form from Dashboard, if the Survey123 Form is already installed on the device, it will not check to see if it is the latest version. Is there a way to force the form to ensure it is always the latest version?
Thank you,
Suddha
